Jenn Air convect. double oven WW2780B Does it have an appl. outlet?
Jenn Air
7 replies to this topic
#1 richg99
richg99
  • 4 posts
  • Flavorite Brew:coffee
Posted 01 December 2011 - 09:56 PM
I have a fairly large microwave mounted above my double oven Jenn air convection oven WW2780B. The microwave is (I think) plugged into a regular 110 volt outlet ...and not into the Jenn air.
I did all of this many years ago and I think that, after I had it all put in...I realized that the double oven probably had an appliance outlet .....which I didn't use.
No problem for years, but now a combination of the 10,000 light (kidding) Christmas Tree; newer, larger big screen TV AND the microwave on the same circuit...is blowing the 15 amp breaker. Without the Christmas tree....or without either of the other items...no problems.
Before I mess up my neat installation...I need to know if there is an appliance outlet on the double oven. I presume that the appliance outlet ( if it exists) would feed off of the wiring for the double oven and might cure my problem. I'll uninstall the microwave ( it is BIG, HEAVY, and about 6 feet off of the floor) and plug it into the oven's appliance outlet if that will help.
I went to the Jenn Air site but the manual that I found there didn't help.
Thanks, and any help appreciated. thanks Rich
#2 Comstock_Services
Comstock_Services
  • 462 posts
Posted 01 December 2011 - 09:59 PM
Is your oven gas or electric?
Far as I can tell, there shouldn't be an appliance outlet or a regular plug any where on that unit.
Edited by Comstock_Services, 01 December 2011 - 10:01 PM.
#3 richg99
richg99
  • 4 posts
Posted 01 December 2011 - 10:03 PM
It is electric...Even if the answer is NO......I am ahead because I didn't have to pull the whole mess apart to find out there isn't one there. R
#4 kdog
    RoughShod
  • 7,428 posts
Posted 01 December 2011 - 10:06 PM
No convenience outlet in a Wall Oven (some ranges have them) - you may just have a weakening 15 A breaker if this is a new issue. Unusual to have kitchen/microwave circuit combined with television room etc - that's against code here
#5 richg99
richg99
  • 4 posts
Posted 01 December 2011 - 10:33 PM
Thank you. Some years ago a local "electrician" came in and dealt with the breaker blowing problem by replacing the original 15 amp breaker with a 20 amp. It "solved" the problem but I knew it wasn't the right way to deal with it.
A month ago, I had a real electrician come in and go over the house wiring He, of course, found that the breaker was the wrong size for the wiring ...so I had him change it back to a 15 .
No issues UNTIL the Christmas tree was put up the other day. We will run the Christmas tree to another outlet ( that doesn't blow when we have the issues) and I thnk that will solve the problem. Thanks for all of your help Rich
#6 kdog
    RoughShod
  • 7,428 posts
Posted 01 December 2011 - 11:34 PM
Wonder why he didn't upgrade it to a dedicated circuit -
No problem for years, is blowing the 15 amp breaker.
:kopkrab:
#7 RegUS_PatOff
  • 30,198 posts
Posted 02 December 2011 - 03:08 AM
:kopkrab:
may be an old house, with old wiring (not in conduit)
#8 richg99
richg99
  • 4 posts
Posted 02 December 2011 - 08:26 AM
Yep, no conduit. In hindsight..I should have had him do it anyhow...but..I forgot about the Christmas tree trouble time. Thanks for all of the help. Great site! R
