Kenmore washer (model # : 11027332600) just fills up, but nothing after that.
Kenmore washer
8 replies to this topic
#1 explorer
explorer
  • 4 posts
  • Flavorite Brew:cider
Posted 03 December 2011 - 09:55 AM
My washing machine stopped working halfway through a wash and will not do anything other than fill up with water. I have since replaced the cover lid and capacitor. I have tested the motor for resistance and everything checks OK except for the high speed wires( white and Blue). I am completely stuck and clueless on what to check next.
#2 certified tech group 51
  • 1,972 posts
Posted 03 December 2011 - 10:41 AM
( cover lid ) ??? Have you checked the pressure switch ??? how about the lid switch ??? The wire diagram is in the console...If it will fill and then will do nothing ( if the lid is closed )......... Then the biggest culprits are the lid switch or the pressure switch.. ( least culprit is the wire harness is off the motor ).......... use a meter to check continuity............... For us highly trained, razor sharp I.Q. NO non-sense techs, Try this, with the timer in a wash cycle and the knob pulled out, we will remove the pressure hose from the pressure switch, put another hose on the switch , blow gently, does it start to agitate ???? For the lid switch, timer set to spin, just jumper the gray and the black wire......... console end................. ( not the green wire )..............( U shaped insulated wire..NOT a paper clip :yikes: )
  • 24,207 posts
Posted 03 December 2011 - 10:59 AM
Part links:
Lid Switch Assembly
Pressure Switch
#4 explorer
explorer
  • 4 posts
Posted 03 December 2011 - 03:54 PM
Thanks to you for your help, but I wanted to add that the water only fills up to whatever level I set the knob to. Does that mean it could still be the pressure switch? I have already replaced the cover lid switch.
#5 RegUS_PatOff
  • 30,198 posts
Posted 03 December 2011 - 11:38 PM
... water only fills up to whatever level I set the knob to. Does that mean it could still be the pressure switch?
could be.. it's a SPDT Switch..
You could test to see if there's 120v AC at the Tan Wire of the Water Level Switch (when it's full)
#6 explorer
explorer
  • 4 posts
Posted 03 December 2011 - 11:51 PM
and yes there is 120 v at the tan wire when the water is full. I am starting to thing that it could be my timer.
#7 RegUS_PatOff
  • 30,198 posts
Posted 04 December 2011 - 12:32 AM
then at the Wash Motor, there should be
120v AC at the Blue wire
and 0v at the Gray wire
Does the Timer "run" after it's filled ?
#8 explorer
explorer
  • 4 posts
Posted 04 December 2011 - 04:56 PM
the timer runs after it 's filled but nothing happens below the timer; and also there is no power at the blue wire, nor the yellow or the white with black stripe wire behind the yellow one.
#9 RegUS_PatOff
  • 30,198 posts
Posted 04 December 2011 - 06:01 PM
... I am starting to thing that it could be my timer.
yes, bad Timer
http://www.repaircli...R=154&N=1060743
