Roper RAX4232PQ0 Washing Machine
washing machine leaking pump
7 replies to this topic
#1 dsm1995gst
dsm1995gst
  • 4 posts
Posted 04 December 2011 - 01:48 PM
I think I've found where it is leaking, and by looking at some parts catalogs online, I think I've identified that part as the pump, seen here:
http://www.repaircli...sp?R=154&N=3296
Strangely enough, it looks like the circle in the very center part has something partially protruding from it, and water is dripping from there.
I guess my questions are - is this fixable? Does the pump have to be replaced? Why would this happen? etc.
Thanks.
#2 Strathy
Strathy
    Kohai
  • 382 posts
  • Flavorite Brew:DP.
Posted 04 December 2011 - 02:33 PM
It happens when either something gets stuck in the pump while spinning at high speed and begins to melt the pump housing ... or if the motor gets too hot (unit overloaded or something wrapped around the agitator) and the shaft of the motor begins the heat up the pump actually melting it.
Neighbour's Appliance Service
Servicing Southern Manitoba, Canada
  • 24,218 posts
Posted 04 December 2011 - 03:33 PM
The picture you posted is just fine-- know exactly what you're talking about, seen it a time or two...
Replace the pump, all good ==> http://www.repaircli...sp?R=154&N=3296
#4 jumptrout
jumptrout
  • 1,126 posts
  • Flavorite Brew:Coors Light
Posted 04 December 2011 - 04:16 PM
It is not a repairable part. Replaceable only.
#5 dsm1995gst
dsm1995gst
  • 4 posts
Posted 04 December 2011 - 09:17 PM
It's actually the other side of the pump that looks like the shaft busted through and is leaking from... I plan on trying to replace the pump tomorrow. I'm assuming there's nothing special I need to know; it looks pretty simple so I'm going to just try it.
  • 24,218 posts
Posted 04 December 2011 - 09:20 PM
No need to ASSume anything-- click the part link I so thoughtfully posted for you, scroll down and there's a how-to video right there.
Who's yer daddy?
#7 Strathy
Strathy
    Kohai
  • 382 posts
Posted 04 December 2011 - 09:22 PM
It's easy.
Pop off the two spring metal clips that hold the pump to the front of the motor.
Pull the pump off of the motor shaft.
Keep a towel and and bucket handy ...
Hold the pump with the hose clamps still attached over the towel/bucket
Release the hose clamps with plyers
Pull the hoses off (some water will come out - but not much if you have a hole in the pump as you describe.)
Reverse to reassemble = do some laundry now ... and have a brew.
Edited by Strathy, 05 December 2011 - 08:30 AM.
#8 dsm1995gst
dsm1995gst
  • 4 posts
Posted 06 December 2011 - 07:25 AM
Who's yer daddy?
Didn't see the link. Already changed the water pump yesterday, luckily it was simple as I expected and no asses were made of anyone.
Thanks for the help everyone.
Also tagged with one or more of these keywords: washing machine leaking, pump
