Dryer not drying DEX1 F&P
4 replies to this topic
#1 merrittna
merrittna
  • 3 posts
Posted 05 December 2011 - 08:21 PM
I have a F&P dryer which I have already replaced the heating elements in. Of the four legs that attach to the elements only 3 are showing 120 volts and one of the elements now gets how. My questions is what is causing the 4th leg to be dead?
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 05 December 2011 - 09:10 PM
DEX1
check that model number again
#3 merrittna
merrittna
  • 3 posts
Posted 05 December 2011 - 10:16 PM
Sorry its a DEGX1
#4 RegUS_PatOff
  • 33,588 posts
Posted 06 December 2011 - 12:19 AM
... Of the four legs that attach to the elements only 3 are showing 120 volts
It's a 240v Heater .. you shouln't be measuring to Neutral ..
You should be measuring 240v AC across each Element.
From your measurements, the leg that is "dead" is either disconnected, OR that Element is bad.
#5 merrittna
merrittna
  • 3 posts
Posted 06 December 2011 - 05:45 PM
If the dead leg is not disconnected which part is responsible for supply the 120 to all four legs? Is it the control assembly? Just making sure before I order the part. Thanks.
