  • Announcements
tiggers
Frigidare FRS24ZSF started popping GFI
18 posts in this topic
Hi all. Weekend repair hobbyist here. I could really use some help troubleshooting a fridge that keeps tripping a GFI.
Here’s the background: Frigidare side-by-side, model: FRS24ZSF about 10 years old. Ice maker is off. The fridge is in the garage (beer and frozen pizza mostlyJ) and has worked off the GFI for the last year (I know “no GFI” but it was the closest plug for a convenient fridge location). One day found the freezer door was ever so slightly open. I’m not sure how long it was going, but it looked like it was forming a nice soft snow bank by the door crack. I closed the door and let the kids know (it just had to be them!) to be sure to keep it closed. Two days later I go out and the fridge had tripped the GFI. Luckily things were still frozen inside so it was all moved into the kitchen freezer quickly.
I started trouble shooting and thought the problem was the excess water I found in the freezer section that was causing a short. But after letting it dry for a couple of days it did not fix the problem.
After playing around with it for a little, I can turn the temperature switch to off, plug in the fridge and lights come on. Turn temperature switch to cool and most times the GFI pops. Sometimes (earlier in the testing) it would turn on and start to cool for a while, but would eventually pop the GFI. I thought at first the defrost cycle might be tripping it, but advancing the timer did NOT do the trick (it would still pop the GFI when the temperature dial is turned from off position). I did try plugging it into a separate 20amp circuit, and it would appear to run, although the fridge lights would dim noticeably when the compressor kicked in. Tried it on a second GFI circuit for kicks, but it still popped the GFI. Followed some instructions for testing the compressor leads, and they checked seemed to check out (2.6, 4.5, 7.0 ohms). Starter capacitor is not shorted as well.
I believe the relay switch is the culprit. It did not look to be in the best of condition. The casing on the relay seemed to be loose, but still integral enough when plugged in to work. It did have a faint smell of burned plastic when I held it up close. I’m guessing that this piece probably overheated when the freezer door was left open.
Before I start throwing down cash for a new relay, should I be checking/testing any other components? From what I’ve already researched it seems to point to this. Or could the relay be a symptom of another problem?
Thank you
It is not recommended to use a GFCI plug with refrigerator - could have a bad relay and/or compressor. Mesure compressor pins to ground (Copper refrigerant lines)
Hi kdog, Thank you for the quick reply.
I'll try to move the fridge to another part of the garage next to a dedicated 20amp circuit, but I'd rather not do that just yet till I find were the problem is that's causing the GFI to pop (my worry is the problem will get worse and fail in the future even though it's on a dedicated 20amp circuit).
I measured the three pins on the compressor against each other (2.6, 4.5, 7.0 ohms), and each pin against all the copper tubing coming out of the compressor, and the ground nut on the compressor mount, and found no measured resistance (i.e. no shorts or conductivity, no audible alarm from the multi-meter). Also figured out how to use my meter to measure capacitance, and the starter capacitor is within specification. The white and red wire leads to the relay are measuring 110volts.
The compressor sounded like it was ok when it was running and cooling (ice would just start to form in the test water bottles) and not popping the GFI.
With the relay and starter capacitor disconnected, the fridge lights come on and the condensate fan will run without any trouble.
... and each pin against all the copper tubing coming out of the compressor, and the ground nut on the compressor mount,
... and found no measured resistance (i.e. no shorts or conductivity, no audible alarm
for this test, OHM meter should be on one of the higher ranges ...
Ok. Repeated measuring the compressor pins to ground (copper pipes) per RegUS_PatOff's suggestion and links (highest ohm range) and found the same: no readings from each pin to the copper pipes.
(I confirmed that there was conductivity between the copper pipes just to make sure I was doing it right :))
So I'm guessing that is a good thing as (I think) it is showing that the windings/electrical path inside the compressor haven't shorted to ground (?)
correct ..
Measuring the resistance from the each winding to ground will only reveal a dead short or a low resistance path to ground. This is rarely seen and usually only in catastrophic failures. Most of the failures of this nature will be a high resistance path to ground that develops slowly over time as the varnish insulation on the motor windings is exposed to higher-than-design temperatures and breaks down. To detect this condition, you need to use a special meter called a Megger (mega-ohm meter). Supco makes a nice, rugged one with different colored LED indicator lights for about $100.
Some of this "leakage" is expected, therefore they do not recommend using GFCI for the product
I finally was able to get my hands on a clamp multi-meter to test the white and red wire amperage into the compressor. It was to difficult to get the clamp around either the red or white wire at the relay, so I had to go about a foot worth of wire from the relay to make the measurement. I’ve not used one of these before, but I don’t think this should matter.
I plugged it into my garage 20-amp circuit and turned the fridge on (again, noticeable dimming of the frig light when the compressor kicked on). The clamp meter seems to be a bit sensitive as to the location of the wire in the clamp when a measurement is taken, so I made sure to hold the red wire in the same location in the clamp as the white wire. The red wire seems to be about .1 amps more than the white wire on average.
Just another note when I tried plugging in the fridge into the GFI (garage and kitchen): first plug-in with the fridge off, and relay disconnected, would trip the GFI. Resetting the GFI would allow the lights to come on, and allow me to turn the fridge on (no compressor, but defrost fan would run). Not sure if it’s another clue as to what’s going on, but it’s what I observed.
I went ahead and ordered a new relay. Even if it isn’t the problem, the fact that it was starting to come apart, along with the old burnt plastic smell, probably should be replaced regardless.
and the amp readings were ??
Follow up: So I went back and wanted to see out what the peak amperage was as I noticed it would drift down to about 1.5-2 amps (depending on where in the clamp I held it) after I put the clamp on. I was curious to see how close to 15 amps (GFI circuit) it was.
Of course the fridge started doing something new confused.gif. After the compressor came on, I would here the relay click, and the compressor go off (first time). Then a few seconds later it would kick back on. It did this a couple of times before it, along with power to the fridge fan/lights, went out, I unplugged the fridge at least once when the compressor was off. Now when I plug it in, the entire fridge is dead (EEKK!). Did something else blow? (breaker on 20-amp circuit is not tripped). If it was the relay, or even the compressor, that died I wouldn’t expect power to the entire fridge to go.
Oh, sorry. After the amperage was reading steady, it was about 1.5 amps with the wire in the middle of the clamp.
Sorry for the deluge of info tonight. I went back to clean up and tried to plug it in one more time. Of course, after posting the above, lights came back on and compressor went on (white wire peaked at about 16.5 amps). Relay started to click again, so I powered down and unplugged. After disconnecting the power I heard the relay click again, so I’m assuming that it’s something inside heat activated to protect the compressor (?). Unless someone has some other suggestions to look at/test, I’m going to leave it off till I get the new relay installed least my fiddling breaks something else.
There's definitely a short somewhere. Check you power cord for shorting. The click that you heard after the fridge was unplugged was probably caused by a discharging start capacitor.
Samurai, we need to have a long talk about this... or maybe post more info about this in a blog. Looks like i'm gonna have to get another tool...o happy day!
The clicking you hear is the compressor cycling on the overload - 16.5 A is WAY too much, you might be lucky and get away for awhile with a new start device, but it sounds like Compressor is on it's way out.
Just curious, what would be causing the fridge lights to go out if there is power at the receptacle?
Edited by DurhamAppliance
Probably the 16.5 A parallel load
I think I've seen that before but was at a loss to explain it. Thanks!
some good info, some not-so-good info, some doesn't apply
