Samsung WF448AAP
Temp Sensor Error
1 reply to this topic
#1 TrenchRT
TrenchRT
  • 1 posts
  • Flavorite Brew:Kieths
Posted 07 December 2011 - 04:12 PM
I was getting a "Temp Sensor Error", replaced the sensor and after 2 loads am getting the error again. Anyone have any ideas?
Thanks in advance!
#2 john63
john63
    Dean of LG Appliantology
  • 2,212 posts
Posted 07 December 2011 - 11:32 PM
The Samsung WF448 washer has an option called---SilverCare.
The hose which sends water from the valve to the SilverCare Module was known to burst.
Customers would describe to me that they're having a problem with the washer "throwing" an error message---"Temperature Sensor Error" ---every 3rd or 4th load of wash.
In addition to this---there's an erratic/intermittent water leak.
Over time---the leak from the ruptured hose has sent water splattering/running down the center/rear of the tub assy(only when SilverCare has been selected for that cycle).
The THERMISTOR (temperature sensor) plug becomes saturated each time, Eventually the pins in the THERMISTOR plug connection have become corroded.
Most owners/users use the SilverCare option on an as-needed basis---which explains the occasional water-on-the-floor complaint.
Inspect the PLUG for the THERMISTOR for corrosion.
Disconnect & re-connect the plug several times to improve the connection---add a dab of NOALOX paste to improve conductivity (available at Lowes/Home Depot).
Replace the damaged WATER HOSE if burst/ruptured.
Also confirm that the hot & cold water hoses are correctly installed (not reversed).
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
