Asko W660 washer won't turn CCW.
Wash Motor Fault Motor Control Unit MCU W660 CCW 8061774 8061399 manual
1 reply to this topic
#1 Scotsail
Scotsail
  • Chief Appliantologist
  • 1 posts
  • Flavorite Brew:Guinness
Posted 09 December 2011 - 02:50 PM
My Asko W660 washer is getting a "motor wash fault".
It is not rotating in the CCW direction but seems to do everything else ok.
I pulled the motor (#8061774) and inspected the brushes. One brush was longer than the other, but both were ok. I cleaned the brushes and commutator and replaced the brushes in the opposing positions. Washer tested with same results.
The motor has 7 leads.
1-2 appear to go to a tachometer located on the end.
3-4 go to the brushes.
I think 5-6-7 go to the stator windings.
The resistance between 1-2 was 68.5 ohm.
3-4 was 3.8 ohm for each of the 18 rotor pair tested through the brushes.
5-6 was 1.7ohm
6-7 was 1.1ohm
5-7 was 0.8ohm.
Do the resistances appear within spec for this motor? I am thinking that my problem may lie in the motor control unit (#8061399). All of the wire connections are clean and look good. The MCU does not show any signs of overheating anywhere.
Does anyone have a service manual, motor winding diagram or MCU schematic?
Thanks for any advice.
Scott
#2 RegUS_PatOff
  • 30,262 posts
Posted 09 December 2011 - 03:58 PM
W660 info
links PM'd
