defrost not working on LG LSC27910TT
4 replies to this topic
#1 vunger1
vunger1
    Yamabushi
  • Chief Appliantologist
  • 76 posts
  • Flavorite Brew:maxwell house regular blend
Posted 09 December 2011 - 07:01 PM
called out to look at this fridge , and evaporator coils are iced over.This service call is close to home ,so I suggested that the customer allow the ice to melt.
I return the next day to diagnose, and upon doing a continuity test , of the heat sheathe ...Meter reads about 40 o.h.m.s.
I then proceed to check heater fuse ,but i cant find it, also cant find the control board........Can someone point me in the right direction to get this unit repaired ?
#2 kdog
    RoughShod
  • 7,433 posts
Posted 09 December 2011 - 07:47 PM
Check this post: http://www.applianto...010#entry158010
And this one: http://www.applianto...__1#entry188668
#3 vunger1
vunger1
    Yamabushi
  • 76 posts
Posted 10 December 2011 - 11:31 AM
Can someone school me on where the control board is located. It is beginning to be a bit embarrasing ,to have to tell the customer I cant find the fuse or the control bd.
Is the fuse wired in line just before the heat sheathe by the evaporator coils?
  • 24,677 posts
Posted 10 December 2011 - 12:33 PM
PMed you the service manual. That awwta be good for some collitch-level skoolin'! Posted Image
#5 vunger1
vunger1
    Yamabushi
  • 76 posts
Posted 07 January 2012 - 03:20 PM
Thanks for the manual, I replaced the board,....more out of guesswork than proper troubleshooting technique.
I did this b4 I got the manual. I was skeptical,as I was thinking it might have been a thermistor problem.
But it has been a month and no call back yet. I hope this is a good thing.
