Samsung Dryer DV448AEG -- Not Spinning
not spinning samsung
25 replies to this topic
#21 quantass
quantass
  • 13 posts
Posted 15 December 2011 - 01:08 AM
John63, it amazes me how much you know about these things!
I removed the cover and first thing i noticed was how much lint was inside the dryer within this area. Is this normal?
I looked around but did not see any foreign objects which could be obstructing the wheel. It looked good. I even tried spinning the drum and i can see the mechanics moving fine. The belt looked in place.
Posted Image Posted Image Posted Image
Perhaps i should reconnect the door plug, reattach the main board case and then START the dryer and watch / listen for the buzz? Though i dont want to start anything until i get the go ahead. :)
#22 john63
john63
  • 1,411 posts
Posted 15 December 2011 - 01:24 AM
Looking at the photo (with the worklight)---that silver DUCT must be removed to gain access to the BLOWER WHEEL for inspection.
Remove the LINT FILTER & place it inside the drum
Remove the 3 screws which secure the *silver* DUCT
Pull the DUCT down & towards you
Inspect BLOWER WHEEL for sock/fabric softener sheet etc.
Yes---the amount of dust indicates *poor venting*
Usually caused by an excessively long-length vent system (much longer than 8 feet)---but can also be a shorter length vent with *too many* 90 degree turns----or a normal-length vent system that is blocked/restricted somewhere between the vent behind the dryer and the outside vent hood of the home/house.
Many customers/owners will say that---yes---when the dryer *was* working---it took a long time to dry clothing.
With heavier fabrics (denims/towels)---the cycle would end and clothing would still be damp-to-somewhat-wet(poor venting).
Great pictures :)
Edited by john63, 15 December 2011 - 12:36 PM.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#23 quantass
quantass
  • 13 posts
Posted 15 December 2011 - 10:32 AM
John63, you got it dead on....
Amazing. I pulled out a tightly wedged sock and ring, and voila the drum was able to move more freely. I havent yet put everything back together so that I can clean out all this lint.
Yes our duct has 2 90' turns before it enters the wall and then there is another 90' turn upward from basement toward ground level. So to be clear the sock and ring entered this fin blowing area thru the lint filter (perhaps the filter wasnt in place?). And the excess lint is due to some material bypassing the filter and entering the duct and because of the many 90' turns it builds up and then backs up?
Any recommendations to reduce the lint debris? Our dryer is prompted up on a Samsung drawer and so standars about a foot or so off the ground. The duct we use is the hard aluminum kind and it must first take a 90' turn toward the ground and then another turn right to go towards the wall. The wall duct appears to travel 4 feet right and then 90' turn upward to groundlevel to exit the home.
Thanks so much John for your BRILLIANT assistance. There is no way i would have figured this stuff out!!
#24 john63
john63
  • 1,411 posts
Posted 15 December 2011 - 12:49 PM
Good job :)
<<<The wall duct appears to travel 4 feet right and then 90' turn upward to groundlevel to exit the home.>>>
That is actually an ideal length---even with three 90 degree turns.
The heavier-than-usual lint/dust accumulation is then---likely from more-than-average use of the dryer.
A typical family of four does 8 to 10 loads of laundry per week----a little over 416 loads per year.
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#25 kdog
    RoughShod
  • 7,428 posts
Posted 15 December 2011 - 03:41 PM
#26 Samurai Appliance Repair Man
  • 24,279 posts
Posted 16 December 2011 - 08:40 AM
Great topic! For others coming along later and reading this, get parts for your Samsung dryer ratcheer ==> http://www.repaircli...ung-Dryer-Parts
Also tagged with one or more of these keywords: not spinning, samsung
