Does anyone make an quick connect drain for self standing icemakers?
Drain Ice maker Plumbing
1 reply to this topic
#1 Wormwood
Wormwood
  • 5 posts
  • Flavorite Brew:Dos Equis
Posted 13 December 2011 - 12:43 PM
I have a GE monogram free standing ice maker. Due to its nature (constantly needing maintenance), I was wondering if there was someone that made drain but with twist-lock fittings? Perhaps (i'm dreaming this up.... So just go with it.) some accordion tubing with a swivel connection that would lock to a bulkhead counterpart mounted on the floor?
I'm a big fanatic about easy of access for both the consumer & repairman. If you can retrieve or even see a filter from an air handler up in the attic, then why even bother in the first place??? So naturally I'm looking for a more robust drainage system than a 3' piece of heater hose shoved down a p-trap under the house.
Thanks!
Steve
#2 jumptrout
jumptrout
  • 1,122 posts
  • Flavorite Brew:Coors Light
Posted 13 December 2011 - 01:28 PM
You could add a small size condensate pump made for these units. Or the PEX fittings could be added to the existing drain hose.
