Kenmore 970-C45172-30 Front Load Super Capacity 3.5 Washer
4 replies to this topic
#1 tdibratto
tdibratto
  • 2 posts
Posted 14 December 2011 - 07:42 PM
My washer does not spin in the spin cycle. I watched it tumble wash. I can see the water drain so pump appears to work. But whether I let it run the whole wash the cycle or specifically ask it to run the spin cycle, it does not spin.
I see no flashing lights so no idea what this could be.
Any ideas?
    Shōgun
  • Master Samurai Tech
  • 30,703 posts
Posted 15 December 2011 - 10:55 AM
Get the tech sheet from inside the washer, usually behind the bottom front panel. It will have information on retrieving and interpreting error codes and troubleshooting this problem. On this machine, most no-spin problems result from either a bad door latch assembly or a bad motor control board.
Edited by Samurai Appliance Repair Man, 15 December 2011 - 12:25 PM.
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 15 December 2011 - 11:04 AM
Kenmore 970-C45172-30 made by Frigidaire
While it's in the Spin Cycle,
is the Door locked ?
Is the Door really locked ?
If so, un-plug the Washer Power Cord from Wall Outlet.
Can you then open the Door right away ? (bad Door Lock Assembly)
OR only after a few minutes ?
http://www.repaircli...R=154&N=1531974
Door-Switch-Assembly-131763202-01235823.
#4 washertech26
washertech26
    Sōhei
  • Appliantologist
  • 124 posts
Posted 15 December 2011 - 10:09 PM
If the is a Frigidaire front loader the washes but doesnt spin sounds like bad door lock too me can be replaced from the front fairly easy, but coming from a tech I guess not fair
#5 tdibratto
tdibratto
  • 2 posts
Posted 16 December 2011 - 10:12 AM
Door lock it was.. thx all. Excellent forum and valuable responses.
