GE GFWN1100LWW
STOPS IN CYCLE
2 replies to this topic
#1 hawgwildtours
hawgwildtours
    Yamabushi
  • Master Appliantologist
  • 98 posts
Posted 14 December 2011 - 09:55 PM
THIS WASHER WILL STOP MID CYCLE AND THE START BUTTON WILL BE BLINKING...ANY IDEAS WILL BE APPRECIATED...ALSO THERE IS ALWAYS WATER IN THE TUB WHEN IT STOPS
#2 DurhamAppliance
    Sho' Nuff Chozin
  • 1,711 posts
Posted 14 December 2011 - 11:20 PM
Check for a clogged pump and check for your drain hose. make sure drain hose is not kinked nor pushed too far down drain pipe. Also check door switch.
Edited by DurhamAppliance, 14 December 2011 - 11:23 PM.
#3 hawgwildtours
hawgwildtours
    Yamabushi
  • 98 posts
Posted 15 December 2011 - 10:07 AM
THE PUMP CLEAN OUT WAS COMPLETLY FULL OF BLACK STINKY SLOP. CLEANED IT OUT AND MACHINE SEEMED TO DRAIN OK. I WILL GO BACK AND CHECK DRAIN AGAIN AND DOOR SWITCH. THANKS
Also tagged with one or more of these keywords: STOPS IN CYCLE
