WFMC3200 Bosch washer ..not working
1 reply to this topic
#1 psue
psue
  • 1 posts
Posted 15 December 2011 - 11:00 PM
my bosch washing machine is not spinning or adgitating but will drain. i want to test the door switch. should i take off the side panel or front to take the switch off?
#2 appl.tech.29501
appl.tech.29501
  • 8,025 posts
Posted 18 December 2011 - 12:55 PM
just remove the spring clamp that holding the rubber boot to the front of the machine. Then you can push the boot inside of the drum and access the door latch. or, if you have a schematic and a meter you can remove the top of the machine and test from the control.
