Learn how to be your own tech line...
hay122
Fridaire front loader wont drainLTF2140
6 posts in this topic
I have a Fridiare front loader serial number is partially destroyed but isLTF 2140...I checked on this forum and cleaned the filter but the clothing is still soakedat the end of a cycle. I tried looking for instructions on how to do the diagnostic test but must have lost that paper. I did try to set the washer onto the drain and spin cycle and it does nothing. The pump does work, I watched it push out water during the cycle.I thought maybe the door lock was borken but during the cycle you cant open the door...so I am completely lost. PLEASE HELP
Ah, Grasshopper..You have broken a ' Rule of The Technical Sheet' ................. Rule #1 'Return tech. sheet to envelope when complete' .................. May you be down wind when Yak pass gas.. :woot: ...................Your's will be more difficult to explain , because you will need to push a few buttons and rotate the knob to run thru the diagnostic tests..... I will peruse thru my small stack of tech sheets that were liberated after the 'Last rites' were administered to a dying Friggy front loader........In the mean time, check all of your wire connections especially at the motor connectors............ Then view the motor speed control board for any damages..................Maybe/hopefully a test sheet will be produced, but, alas, you are only a Grasshopper.....I do not know if you are worthy of viewing the information...You did lose your tech sheet ... :sillytongue: .....
... The pump does work, I watched it push out water during the cycle
... .I thought maybe the door lock was borken
1) does it pump all of the water out ?
2) while it's in the Spin cycle, unplug the Power Cord from the Wall Outlet.
can you now open the Door right away,
OR only after a few minutes ?
... LTF2140
looks god to me
ES0, ES1, ES2, ES3, FS0, FS1, FS2
