Kenmore Gas Dryer Thermal Fuse 417.79042990
kenmore gas dryer thermal fuse 417.79042990
6 replies to this topic
#1 heritage
heritage
  • 5 posts
Posted 16 December 2011 - 11:23 PM
Waiting for my Kenmore Gas Dryer 417.79042990 to dry my karate pants I came to notice a burnt electrical smell in the air. Realizing the dryer was not running I snatched open it's door and noticed the light inside was on but the clothes were not dry. A snap kick was quickly loosed on the unit shutting it's door. A round house to the start button and no signs of life.
The light comes on, the drum spins freely. (My pants had originally snagged on the edge of the lint filter and had stopped the drum.) Is here a thermal fuse on this unit? If so how does one get to it? Thanks!
Edited by heritage, 16 December 2011 - 11:24 PM.
#2 RegUS_PatOff
  • 30,192 posts
Posted 16 December 2011 - 11:50 PM
... Is here a thermal fuse on this unit?
no Thermal Fuse on that model,
only auto-reset Thermal Limiters
Doesn't heat at all ?
  • 24,207 posts
Posted 17 December 2011 - 01:04 AM
Howdy, Heritage. Not sure if your dryer has this or not, but on some models, the engineer's were thoughtful enough to leave a little peep hole in the bottom of the front panel so we could get some eyeball action on the ignitor. Can still be done without it, just a lot slicker this way. What you'd be looking for is seeing if the ignitor glows initially and then in a few seconds you hear a click and the ignitor stops glowing. That's the telltale sign of bad gas valve coils ==> Gas Valve Solenoid Set
And here's how to replace 'em:
#4 heritage
heritage
  • 5 posts
Posted 17 December 2011 - 02:28 AM
Sure enough, tried it after it had sat for a few hours and now is working fine. Thanks!
I think now that it did not leave us high and dry or in this case low and wet right before Christmas. Will keep it around and buy the maintenance kit for it. (Has been pinching some items between the frame and the drum.).
#5 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,463 posts
  • Flavorite Brew:Killians Red
Posted 17 December 2011 - 08:32 AM
That is the telltale sign of the front bearing failing ... prolly oughta get a look at that rear "trailer ball" bearing too...
#6 kdog
    RoughShod
  • 7,428 posts
Posted 17 December 2011 - 02:23 PM
Link to Maintainence Kit :  http://www.repaircli...er=417.79042990
  • 24,207 posts
Posted 17 December 2011 - 02:29 PM
And how to install it: :dude:
Complete maintenance and tuneup kit for a Kenmore-Frigidaire dryer
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 17 December 2011 - 02:31 PM
Getting sick of all that thumpin', bumpin', rattlin', and moanin' going on inside that dryer when you run it? For just a few bucks and little bit of handiwork, you can make that dryer purr like a brand new one! You'll save money on your electric bill, too because the dryer will run more efficiently. ...
Read Full Entry →
