Asko T701 dryer running LOUD
7 replies to this topic
#1 hcostanzo
hcostanzo
  • 3 posts
Posted 17 December 2011 - 09:57 AM
I have an Asko T701 dryer that is heating and drying fine, but running so loudly that I have to close the laundry room door to hear myself think in the kitchen. Also, it seems that I'm getting very little lint in the lint trap. I'm not sure if these symptoms are related, however they seem to have started around the same time. Thanks.
    Shōgun
  • Master Samurai Tech
  • 31,409 posts
Posted 17 December 2011 - 10:23 AM
The exact type of noise can help identify what the problem might be: a squealy noise, thump-thump, etc. Best thing would be if we could listen to a video and then we could let you know what the cause probably is. If you can shoot a video with your camera and upload it to Youtube, that would be helpful. Otherwise, the only thing I can tell you is that you'll need to open it up and look for the bad actors.
#3 hcostanzo
hcostanzo
  • 3 posts
Posted 18 December 2011 - 03:23 PM
Ok, I made a video of the dryer running with my husband trying to locate the source of the noise. . .
Hopefully the link works and helps describe my issue. Thanks!
#4 rwfisher
rwfisher
    Ikkō-ikki
  • 52 posts
Posted 18 December 2011 - 07:39 PM
If it's like the 7005, there is a system of hard plastic ducting to vent the air from the drum through the fan and out the vent. The sections are friction fit...I wonder if they've pulled apart for some reason and are vibrating against the metal casing. Is any air coming out the vent?
    Shōgun
  • 31,409 posts
Posted 18 December 2011 - 07:50 PM
Great video! Have you eyeball-confirmed that the drum is tumbling? Has that reminiscent sound of a motor spinning with a broken belt. Anyway, you're gonna need to open this puppy up and get some eyeballs on the guts-- the problem will no doubt be apparent. This manual will help you-- it's a Freaky Festivus present. Don't never say I never gived you nuttin'! ==> ASKO T700-Series Dryer Service Manual
#6 hcostanzo
hcostanzo
  • 3 posts
Posted 18 December 2011 - 08:27 PM
Yes, the drum is tumbling and is still drying clothes fine. Thanks for the manual. I guess we'll have to open 'er up and see what's up.
#7 rwfisher
rwfisher
    Ikkō-ikki
  • 52 posts
Posted 18 December 2011 - 09:28 PM
Wise man say beware the sharp edges of sheet metal.
#8 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 18 December 2011 - 10:04 PM
I think they were designed by ex-engineers from the Wilkinson Sword Razor Company :whistling:
