Maytag range won't turn off/MER5552BAW
5 replies to this topic
#1 bdweller
bdweller
    Ikkō-ikki
  • 49 posts
Posted 18 December 2011 - 08:32 PM
My two year old Maytag oven/range won't run off. Last night, I was using the oven and turned it off. Later, we noticed that the red light indicating oven or range use was still on and the oven was hot. We tried many times to hit buttons, turn the dials and disconnect the circuit, but each time the red indicator light came on and the oven preheated. Now, I just have to cut the breaker to keep it off. Any ideas on what to do?
Thanks, BDWeller
#2 DurhamAppliance
    Sho' Nuff Chozin
  • 5,901 posts
Posted 18 December 2011 - 09:11 PM
More than likely your circuit board/timer is bad. http://www.repaircli...1M75860/1515089
www.DurhamApplianceThrift.com
#3 bdweller
bdweller
    Ikkō-ikki
  • 49 posts
Posted 19 December 2011 - 07:04 AM
Any tips on removing the top assembly? I've taken a number of screws out, but not seeing which ones are holding it in place.
thanks, BDWeller
#4 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 19 December 2011 - 07:23 AM
Maintop Assembly (Coil Element Models)
1. Turn power off.
2. Open oven door and remove screws securing maintop to oven chassis, located on the outside edges of the maintop.
3. Move the top assembly down, then slightly up and toward the front to unhook the back edge from the backguard.
4. Label and disconnect wire terminal plugs from the maintop assembly.
5. Lift maintop assembly from the oven chassis.
6. Reverse procedures to reinstall maintop assembly.
#5 bdweller
bdweller
    Ikkō-ikki
  • 49 posts
Posted 19 December 2011 - 10:40 AM
So, my local appliance parts store has the part for $220. I can't wait for mail order, as I've got to use the range asap.
Is there anything else I should check? That's a lot of dough to sink into something I can't return.
Thanks again, BDWeller
#6 RegUS_PatOff
  • 33,588 posts
Posted 19 December 2011 - 10:49 AM
... local appliance parts store has the part for $220.
... I can't wait for mail order
... That's a lot of dough to sink into something I can't return.
http://www.repaircli...R=154&N=1515089
$ 182 + $ 27 FedEx overnight shipping = $ 209 returnable
Circuit-Board-or-Timer-5701M758-60-01090
How to remove the top assembly on a Maytag model MER* electric range to replace the clock circuit board
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 19 December 2011 - 06:25 PM
1. Turn power off.
3. Move the top assembly down, then...
Read Full Entry →
