careh
Noisy bearings? Kitchenaid 4KUDC220T4
3 posts in this topic
Our older Kitchenaid dishwasher makes a loud intermittent (bearing like?) sound during its runs. The sound typically occurs every time at the end of a cycle when the motor is stopping. From time to time it also sounds during the wash cycle - and is pretty loud. After a while it may go away or not - it sort of has a mind of its own.
The unit washes the dishes just fine - so if it is an easy fix - I'd just as soon fix it - then replace it.
I saw on this site another post talking about how the bearings could begin to leak and that would be seen by water found under the motor. I took the front kick panel off and saw no signs of water. I recorded the sound and can email it to you if you send me an email address (the file is too large to be attached to this post). Attached is a picture of the bottom of the unit showing no evidence of water.
I wanted to know how to take off the top filter screen as there was mention in another post that crud could get in the food chopper mechanism so I included a picture of the inside of the unit with the spray arm removed. I've felt all around the bottom and can feel no crud - but if I am supposed to remove the top I can do so - just let me know what screws to remove.
Thanks for the help.
Hmm -only the first picture got posted so here is the one of the inside of the unit
post-65973-0-97147500-1324270373_thumb.j
post-65973-0-15087800-1324271057_thumb.j
Here is a sound clip of the sound -At the beginning it says 'avs media demo' as I had to trim the audio clip to fit the site size limitation - but just after that the sound starts.
squealing sound.mp3
I think you need to apply this technique:
<object type="application/x-shockwave-flash" width="400" height="300" data="http://www.flickr.com/apps/video/stewart.swf?v=109786" classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000"> <param name="flashvars" value="intl_lang=en-us&photo_secret=0acf7fff98&photo_id=5180731176"></param> <param name="movie" value="http://www.flickr.com/apps/video/stewart.swf?v=109786"></param> <param name="bgcolor" value="#000000"></param> <param name="allowFullScreen" value="true"></param><embed type="application/x-shockwave-flash" src="http://www.flickr.com/apps/video/stewart.swf?v=109786" bgcolor="#000000" allowfullscreen="true" flashvars="intl_lang=en-us&photo_secret=0acf7fff98&photo_id=5180731176" height="300" width="400"></embed></object>
