Bosch WVT1260 Washer Dryer.. No heat on the drying cycle
drying cycle WVT1260 Bosch
3 replies to this topic
#1 purl
purl
  • 2 posts
  • Flavorite Brew:Bud
Posted 19 December 2011 - 10:07 AM
Bosch WVT1260 Washer Dryer..I'm not getting any heat on the drying cycle...
- All 3 thermostats/cut-outs check-out OK.
- Element OK - measures 35 Ohms.
- 240VAC on both sides of heating element.
- Dryer motor not running.
- No 240VAC on heater motor starter capacitor (on either side).
- Water trickle into condensation chamber OK.
Seems like neither the heater element or dryer motor are not being turned on.... does anyone have any ideas what could be causing this?
Drum is turning ok, and seems to go through drying cycle, but no heat...
Are there any other temperture cutouts or sensors I should take a look at?
Any experts out there who can point me in the right direction?
#2 RegUS_PatOff
  • 30,190 posts
Posted 19 December 2011 - 10:54 AM
... Drum is turning ok,
If the Heating Element is good (35 OHMs), and there's 240v across it, it should be glowing
Motor not running, but Drum is turning ? :kopkrab:
Also tagged with one or more of these keywords: drying cycle, WVT1260, Bosch
