Kenmore 110.29852991 Misbehaving - Not Spinning - HELP
110.29852991 not spinning
12 replies to this topic
#1 zeethree
zeethree
  • 10 posts
Posted 19 December 2011 - 06:16 PM
Unit will turn on - just as always - agitate - but NOT spin. Even with no clothes in it.
The unit will drain -
I've seen various posts, but could not fine one that was exactly like this - if you were me - what parts would you buy first to try to replace?
#2 kdog
    RoughShod
  • 7,428 posts
Posted 19 December 2011 - 06:19 PM
Can you help it get started by giving the basket a whirl with your hand ?
#3 RegUS_PatOff
  • 30,299 posts
Posted 19 December 2011 - 06:44 PM
After it Drains, try opening the Lid for 5 seconds, then close the Lid
Does it Spin now ?
#4 zeethree
zeethree
  • 10 posts
Posted 19 December 2011 - 07:14 PM
OK so I misinformed a little info.
Giving a whirl with clothes in does not help start it -
however - it has not been tried yet with no clothes. Does that help narrow it down that it can't be assisted with starting the spin?
#5 washertech26
washertech26
    Sōhei
  • Master Appliantologist
  • 124 posts
Posted 19 December 2011 - 08:24 PM
Does it agitate and not spin?
Does it to neither?
If it spins but not agitate reach under the agitator if you can barely get your fingers under it thats ok but if there is lots of room then needs agitator and basket drive...
Need more information
#6 zeethree
zeethree
  • 10 posts
Posted 20 December 2011 - 02:44 AM
It agitates, but does not spin
#7 kdog
    RoughShod
  • 7,428 posts
Posted 20 December 2011 - 07:37 PM
After the unit drains, what happens ? Does the motor continue to run ?
#8 zeethree
zeethree
  • 10 posts
Posted 21 December 2011 - 04:08 PM
Ok - went by today and observed the machine.
With no clothes in - it turns on - and agitates, but not like it normally agitates - slower...like it's struggling. No matter what setting it is put on - but no funny noises.
When comes time to spin - nothing happens. You can hear the motor on and trying, but thats about it. Even if you give it a whirl with no clothes - Same result. We tried holding the sensor depressed with our finger to observe.
It will drain fine on it's own.
What do you think?
#9 kdog
    RoughShod
  • 7,428 posts
Posted 21 December 2011 - 04:11 PM
Prolly just a bad coupling - Moron that here: http://fixitnow.com/...t-drive-washer/
#10 RegUS_PatOff
  • 30,299 posts
Posted 21 December 2011 - 05:12 PM
OR may be a bad Speed (Cycle) Switch
(trying to run two speeds at once)
http://www.repaircli...R=154&N=1454262
#11 zeethree
zeethree
  • 10 posts
Posted 24 December 2011 - 03:57 AM
Both parts are not expensive at all, I just ordered the coupling. [Part link ==> Motor Coupling ]
RegUS_PatOff - What do you mean try to run two speeds at once?
Do you agree to try the coupling first as well - then the switch if not?
Edited by Samurai Appliance Repair Man, 24 December 2011 - 11:02 AM.
Added part link to motor coupling
#12 jumptrout
jumptrout
  • 1,143 posts
  • Flavorite Brew:Coors Light
Posted 24 December 2011 - 07:24 AM
Go ahead and remove the coupling. You will know quickly if it is bad.
#13 RegUS_PatOff
  • 30,299 posts
Posted 24 December 2011 - 09:10 AM
... RegUS_PatOff - What do you mean try to run two speeds at once?
... Do you agree to try the coupling first as well
1) if the Switch is bad, it may be connecting two speeds at once... could be tested with a meter.
2) yes
