Whirlpool Washer (WTW4800XQ) Won't Spin
Whirlpool Washer Spin
3 replies to this topic
#1 Notyetwise
Notyetwise
    Ikkō-ikki
  • Chief Appliantologist
  • 20 posts
  • Flavorite Brew:Blue Moon
Posted 21 December 2011 - 10:39 AM
Not Sure if this is the correct Model Number but after some searching on the web I found what looks close. Can't find the model number anywhere on the machine. The only clue is the words, "Fabric Sense System". This is a direct drive machine though.
Washer will fill, agitate and empty, but won't spin. When in spin, the Block Basket Drive turns slowly and jerkely. I can easily stop it with my hand. Is this a Spin Tube problem or a Transmision problem? Or something else?
Thanks!
#2 DADoESTX
DADoESTX
    Kohai
  • 262 posts
  • Flavorite Brew:Iced tea with a spike of earl grey
Posted 21 December 2011 - 07:13 PM
I don't believe the links provided above are relevant in this case. Sources indicate WTW4800XQ0/1/2 is a new-fangled VMW unit, not an "old-style" direct drive.
#3 washertech26
washertech26
    Sōhei
  • Master Appliantologist
  • 124 posts
Posted 21 December 2011 - 08:19 PM
Wow I am a little out of touch I have never even seen that machine before
  • 24,698 posts
Posted 21 December 2011 - 10:59 PM
You are Correct, Brother Dado-- I just took Notyet's statement that this was a direct drive washer, in violation of the Golden Rule of Appliance Repair: Never trust customer diagnostics. I have removed my post and chastised myself with an industrial-strength scrotum scrubber.
Some background info on this machine:
Whirlpool Vertical Modular Washer (VMW), United Servicers Regional Training in Albany, NY
Read the comments, too.
The two most common problems are bad lid switch and bad mode shifter.
