Maytag Neptune Mod#MAH3000AWW wont spin
2 replies to this topic
#1 deezus
deezus
    Kohai
  • Chief Appliantologist
  • 358 posts
Posted 21 December 2011 - 04:02 PM
Hi, this unit wont spin. If I hold in the start button while timer is set to spin it will lock door and drain pump will run but no spin?? The tech sheet says it would be the Machine control that is atfault but I am hearing from friends who are techs that it mostl likely will be a motor control/motor upgrade kit??? help please...
#2 kdog
    RoughShod
  • 7,466 posts
Posted 21 December 2011 - 04:06 PM
Start by testing the motor - Moron that here: Basic Motor Function Test for Early Model Maytag Neptune Washers
#3 washertech26
washertech26
    Sōhei
  • Appliantologist
  • 124 posts
Posted 21 December 2011 - 08:26 PM
Does it agitate? If it does neither the check the black an white wires to the motor control board bottom right hand side of the make.. If it agitate but doesn't spin then that could be several things...
