Whirlpool Heat Element Not Turning Off LER7646EQ0
#1
Posted 21 December 2011 - 08:36 PM
#2
Posted 21 December 2011 - 08:43 PM
#3
Posted 21 December 2011 - 08:49 PM
thanks for quick response
#4
Posted 21 December 2011 - 08:57 PM
... but the element does not turn off. .
... gets hot, pops circuit breaker..
1) Cycling Thermostat may be "stuck"
http://www.repaircli...sp?R=154&N=2893
2) although, it shouldn't blow the Breaker if it does stay ON...
and you said there's is no heat in the Air-Fluff Cycle ?
It may also be a weak Breaker
#5
Posted 21 December 2011 - 09:10 PM
2. correct, no heat in "air fluff" mode, but dryer runs fine and does NOT trip circuit breaker..
for what it's worth, i've attached some pics. . thanks
Picture 001.JPG 58.71K
13 downloads
Picture 002.JPG 64.73K
12 downloads
#6
Posted 21 December 2011 - 09:18 PM
#7
Edited by Strathy, 21 December 2011 - 09:26 PM.
Servicing Southern Manitoba, Canada
#8
Posted 21 December 2011 - 09:34 PM
Picture 003.JPG 65.5K
14 downloads
Picture 004.JPG 60.18K
15 downloads
#9
Posted 21 December 2011 - 11:24 PM
OK ... this is dangerous, but this is what I would do to narrow it down. Essentially we want to find out if power is being supplied to the element from L1 or L2 or both when it is off. You have to be very careful doing this - consider yourself warned ... 240v will do damage to you.
***Unplug the dryer.***
Take one of the red wires off of the heating element - does not mater which one. Bend it out of the way so that it is not close to any ground.
Plug dryer back in.
Turn unit on - it will not heat, but should be sending power to the red wire you have disconnected and to the terminal that you took it off of. Check that - put one lead on the wire that is out in the open and the other on the terminal. You should be seeing 240 volts there. Now open the door. As you said the element continues to heat even though the unit is not running. Now check those points again. Do you have 240 volts? If not, then check each one to ground. Do you have 120 volts on one side? If so which side? With this information we can decide if the power is coming through the motor (centrifuge switch) or the timer.
Please don't electrocute yourself.
- Samurai Appliance Repair Man, kdog, Comstock_Services and 1 other like this
#10
Posted 21 December 2011 - 11:31 PM
what shuts OFF when the Door is opened ?... it spins and starts heating as normal, will shut off if i open door, but the element does not turn off.
- kdog likes this
#11
Posted 21 December 2011 - 11:41 PM
the entire dryer shuts off when i open the door, as normal . .and . .Strathy, when i open the door the heating element DOES shut off as well...
#12
Posted 21 December 2011 - 11:50 PM
If not, then you need to get an amp-probe on first the black line and then the red line to see which side is drawing the high amps that are blowing the breaker.
- Samurai Appliance Repair Man and DurhamAppliance like this
#13
Posted 22 December 2011 - 12:31 AM
Has the *cause* of the failed THERMAL LIMITER been identified?
Was the dryer taking twice or three times as long-to-dry before the THERMAL LIMITER failed?
In *most* cases---this is caused by a partial or complete blockage in the vent system.
Start/run the dryer with rear exhaust vent disconnected.
Is the air flow at the rear exhaust *strong*?
If no---there's an obstruction in the BLOWER HOUSING that needs to be cleaned/removed.
If yes---check the rest of the vent system from the duct that was disconnected behind the dryer---all the way to---the outside vent hood of the home.
If this vent system is very long in length and /or *buried* in the wall of the home---a professional vent cleaning company should be consulted to FULLY clean-out the unseen/unreachable portion of the vent system.
<<< heater element comes on, then stays on during normal cycle .. will not turn off until circuit breaks. . is quite hot.>>>
Yes---the HEATING ELEMENT and the area around it can become---seemingly---alarmingly hot. This is normal.
Is there *any* other area of the dryer that seems out-of-the-ordinary hotter than before?
If observed---from *behind* the dryer---will the HEATING ELEMENT cycle on & off----ever?
NOTE: If this dryer has been taking an abnormally l-o-n-g time to dry laundry----for weeks-on-end...
And...
Your whole house circuit breaker/fusebox is more than 10 years old...
The CIRCUIT BREAKERS may have less-than-tight wires that need to be tightened (electrician) again to prevent tripping continuously under a "load".
or...
The CIRCUIT BREAKER is worn/faulty.
Edited by john63, 22 December 2011 - 12:52 AM.
- Samurai Appliance Repair Man, kdog and Comstock_Services like this
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#14
Posted 22 December 2011 - 02:34 PM
No other area of the dryer seems out-of-ordinary hot other than the element and housing. .
And yes, i have observed the dryer cycling with the back panel off so i could watch the heat element. . it stays on when you start a normal load until the circuit breaks. . you can open the door and it shuts off ..
#15
Posted 22 December 2011 - 03:05 PM
Dryer Cabinet must be fully assembled for correct air-flow
Check the temperature at the Dryer Vent:
Dryer Vent
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
#16
Posted 22 December 2011 - 05:34 PM
"until the circuit breaks"---------> Does the house/home 30 AMP CIRCUIT BREAKER trip?
Or is the dryer CYCLING THERMOSTAT turning off the HEATING ELEMENT after 3 to 4 minutes of run time?
If so---I believe RegUS had the correct answer in post #4
Edited by john63, 22 December 2011 - 05:46 PM.
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#17
Posted 22 December 2011 - 05:41 PM
The cycle thermostat and the high limit thermostat are both in series with the heater. Either one should control the temperature to cycle the heater off. The control thermostat senses exhaust duct temperature. The high limit senses element duct temperature.And yes, i have observed the dryer cycling with the back panel off so i could watch the heat element. . it stays on when you start a normal load until the circuit breaks. . you can open the door and it shuts off ..
Even though the high limit has been replaced it may be bad.
The control thermostat can be verified using the thermometer as Reg U.S. described.
You should also take a amp reading on the heater while running.
As someone else stated,it may be a weak breaker.
#18
Posted 27 December 2011 - 12:29 AM
How to test the power supply for the heater in an electric dryer for both L1 and L2
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 21 December 2011 - 11:59 PMOK ... this is dangerous, but this is what I would do to narrow it down. Essentially we want to find out if power is being supplied to the element from L1 or L2 or both when it is off. You have to be very careful doing this -...
Read Full Entry →
