Kitchenaid Dishwasher Chopper Delete?
9 replies to this topic
#1 Southern
Southern
    Yamabushi
  • Master Appliantologist
  • 93 posts
Posted 22 December 2011 - 11:26 PM
I have a Kitchenaid KUDP01FLSS6 dishwasher that twice a year I have to clean the crud (mainly seeds) from the chopper screen due to the dishwasher not cleaning the dishes properly. Once the chopper assembly is cleaned the dishwasher works great.
My question is can I remove the screen from the chopper assembly since the dishwasher is piped to my sink disposal? I see no advantage to chop the food up to run thru the sink disposal and by not having the chopper screen from getting clogged the dishwasher will keep the dishes cleaner longer.
My concern with removing the screen is that the motor impeller or discharge hose may plug up due to the larger crud being passed.
Any thoughts?
#2 kdog
    RoughShod
  • 7,428 posts
Posted 22 December 2011 - 11:52 PM
Solution - place debris in garbage can prior to loadong dishwasher - dishes in; seeds/debris out
#3 Southern
Southern
    Yamabushi
  • 93 posts
Posted 23 December 2011 - 08:15 AM
It would be easier to sell off my kids & wife.
#4 RegUS_PatOff
  • 30,221 posts
Posted 23 December 2011 - 09:02 AM
… and remember, no matter what the salesman says,
it’s a dishwasher, not a garbage disposal.
:whistling:
#5 Southern
Southern
    Yamabushi
  • 93 posts
Posted 23 December 2011 - 10:37 AM
:whistling:
My oldest son who is a Plumber tells me that the garbage belongs in the trash can not the sink.
#6 Chat_in_FL
Chat_in_FL
    Senpai
  • PipPipPipPip
  • 897 posts
  • Flavorite Brew:Variety is the spice of life!
Posted 25 December 2011 - 09:21 AM
Any thoughts?
Replace the chopper, most likey the blade is not spinning and the mesh is clogging as a result. When you turn the chopper blade by hand, it should turn the pump if it is engaged properly.
Mother Teresa
#7 Southern
Southern
    Yamabushi
  • 93 posts
Posted 25 December 2011 - 01:26 PM
I believe that the chopper is working fine, it's just not capable of chopping seeds or broken glass. Once I clear the debris it wasn't designed to chop it works fine. My original question is if I remove the screen will I cause other problems?
#8 kdog
    RoughShod
  • 7,428 posts
Posted 25 December 2011 - 04:35 PM
Of course, the circulation pump is not designed to circulate Glass and Seeds either
#9 Chat_in_FL
Chat_in_FL
    Senpai
  • PipPipPipPip
  • 897 posts
Posted 26 December 2011 - 08:36 AM
It is just that the chopper screen will not clog if the blade is spinning...
Mother Teresa
#10 Southern
Southern
    Yamabushi
  • 93 posts
Posted 26 December 2011 - 09:17 AM
Thanks, I will leave the chopper assembly intact. I will need to instruct my family to manually wash the juice extractor or to empty it of all seeds before tossing it into the dishwasher.
Is there a maintenance mode I can put my dishwasher in to verify if the blade is spinning while I have the cover off?
