      5
      All Appliantology tech members are invited to join in this workshop on all things Appliantological.
      We have a special session planned for this one. Instead of the usual Show 'n Tell on a technical topic, we're going to post tech sheets in the comments to this Calendar Event (scroll down to see what's posted so far) and ask specific questions that can only be answered by reading the tech sheet. If you at least try to answer the questions beforehand, you'll get a lot more out of it. The tech sheet and the questions are posted in the comments section below.
      Your mission, if you should choose to accept it, is to check out the questions for each one and try to answer them ahead of time. Then come to the Dojo to see how well you did!
KEMS307DBL6 Kitchen Aid Oven & Microwave Combo - Service Manual Request
ReliableApp
  • ReliableApp
  • RegUS_PatOff
KEMS307
MWCOMBO KEM KEH.pdf 23 MB
Whirlpool_Range_Oven_Faultcodes.pdf
KEMS307DBL6
Tech Sheet - 4452028.pdf
links PM'd
Link to comment
