Frigidaire FTF2140ES1 won't spin in a normal cycle
frigidaire FTF2140ES1 front loader
22 replies to this topic
#1 cannotfit
cannotfit
  • 13 posts
Posted 24 December 2011 - 12:12 AM
The washer stopped spinning in any regular wash cycle (still drains, still tumbles). On inspection I found the diagnostic code instructions and it spins fine there. Error code 43 (replace control board).
The belt broke (which when it broke took out a shock, which I also replaced) when I was using the diagnostic mode to wash loads -- saving my pennies for the control board.
Read on here that the wax motor was a common fail. Replaced the door switch with no improvement.
Replaced the control board. No improvement.
Just now tried replacing the speed control board. No improvement.
What have I missed?
Thank you in advance.
#2 RegUS_PatOff
  • 30,255 posts
Posted 24 December 2011 - 12:15 AM
While it's in the Spin Cycle,
Is the Door Locked ?
Is it really locked ?
If so, then unplug Power Cord from the Wall Outlet.
Can you then open the Door right away ?
OR only after a few minutes ?
It may also be a broken / disconnected wire between the Door Lock Assembly and the Main Controller
#3 cannotfit
cannotfit
  • 13 posts
Posted 24 December 2011 - 12:37 AM
It won't do a spin cycle :(.
I have left the cycle going for 1 minute (not spinning, just making an "urrrur urrur" sound) and the door opens easily.
I'll recheck the wires.
#4 RegUS_PatOff
  • 30,255 posts
Posted 24 December 2011 - 12:48 AM
check the Door Lock while it should be in the Spin Cycle ...
If the Door isn't actually locked, it won't Spin
#5 cannotfit
cannotfit
  • 13 posts
Posted 24 December 2011 - 01:22 AM
Okay, I took the door switch apart and plugged it into the machine where I could see the workings. I unscrewed the latch from the door and plugged it into the lock. On turning the machine on and setting it to spin and then touching the two contacts the wax motor would connect, I get a spin! Apparently the replacement door switch assembly I purchased was defective :(.
I'm ordering a new one and hopefully it will work perfectly.
#6 kdog
    RoughShod
  • 7,428 posts
Posted 24 December 2011 - 02:07 AM
http://www.repaircli...mber=FTF2140ES1
Door-Switch-Assembly-131763202-01235823.
#7 cannotfit
cannotfit
  • 13 posts
Posted 24 December 2011 - 12:16 PM
Reinstalled the old door latch mechanism to start washing again, but it won't do anything (even in diagnostic mode). Giving an error 13 - water leak or air bell leak. There is no water leaking, can't find info on the air bell. Is it called something else?
#8 RegUS_PatOff
  • 30,255 posts
Posted 24 December 2011 - 01:13 PM
... error 13
are you sure it's not Error 14 - Dispenser Drawer Reed Switch ?
count the total number of Start Light Flashes, (including during the other lights flashing) ... 3 or 4 ?
#9 cannotfit
cannotfit
  • 13 posts
Posted 24 December 2011 - 01:27 PM
Just 3
#10 cannotfit
cannotfit
  • 13 posts
Posted 24 December 2011 - 01:33 PM
Start flashes once. All flash 3. 13. Or is it 31?
Now I'm confused.
No, wrong again.
Start and the five indicator lights flash once, then the five indicator lights (no start light) flash 3 times.
#11 RegUS_PatOff
  • 30,255 posts
Posted 24 December 2011 - 01:41 PM
first digit = 5 indicator lights flash how many times ?
Second digit = total number of Start Light flashes (including during 5-light flashes) how many times ?
watch video
http://fixitnow.com/...nt-load-washer/
#12 cannotfit
cannotfit
  • 13 posts
Posted 24 December 2011 - 01:55 PM
13
One five lights, three five lights + start :)
Sorry, I have that backwards.
one five lights + start and then three five lights alone.
They have it backwards in teh Tech Data Sheet. Hence my confusion.
Thanks for the video, it cleared it right up.
13
So, what is the air bell?
#13 RegUS_PatOff
  • 30,255 posts
Posted 24 December 2011 - 01:59 PM
First digit = the five-lights flashed a total of 4 times
Second Digit = total number of Start Light flashes = 1
= Error 41
any Error 4x is usually a Door Switch problem
did you watch the Error 43 video ?
five lights flash a total of 4 times
start light flashes a total of 3 times
#14 cannotfit
cannotfit
  • 13 posts
Posted 24 December 2011 - 02:31 PM
Ok, I'm confused again. Did we watch the same video? In the video light row + start blinks 4 times and then light row alone blinks one time. Is that error 41 or error 14?
My washer, light row + start blinks 1 time and light row alone blinks 3 times.
Neither the ones on the video nor mine are blinking like the Tech Data Sheet says they should:
"The code is obtained by counting the number of times the lights flash. Example E24: The five indicator lights would flash twice indicating the 2 and the START indicator light will flash four times indicating the 4. The five indicator lights and the START indicator light start flashing at the same time."
#15 cannotfit
cannotfit
  • 13 posts
Posted 24 December 2011 - 02:42 PM
Okay, I see what you are saying.
After reading this lovely thread and realizing I've been getting the occasional grease streak in my laundry, I'm guessing the bearings are failing and I'll be looking for a new washer instead of repairing this one :(.
And thank you for the video. Now I realize that my original 43 error was 47. That makes a heck of a lot more sense now.
Domo! Beer fund to increase shortly :).
What is the going rec. for a new front loader now?
#16 RegUS_PatOff
  • 30,255 posts
Posted 24 December 2011 - 02:47 PM
... Ok, I'm confused again.
... Did we watch the same video?
... In the video light row + start blinks 4 times and then light row alone blinks one time. Is that error 41 or error 14?
1) yes,. you are :blink: ;) (Frigidaire :woot: )
2) yes, we did
3) no ... in the video, count again:
First Digit ... look only at the right row of lights ... count 1, 2, 3, 4,
then continue to watch when he runs it again for the Second Digit ... look only at the Start Light 1, 2, 3
43
Frigidaire :woot:
#17 cannotfit
cannotfit
  • 13 posts
Posted 24 December 2011 - 03:02 PM
See, the confusion came from the directions to watch the video. I did. However, I did not READ the writing under the video until later, lol! I needed to both watch AND read ;).
Thanks again!
I thought I saw a rec posted for new front load washers. Was it one of the pages here? Or at repairclinic maybe? I'll keep searching.
#18 RegUS_PatOff
  • 30,255 posts
Posted 24 December 2011 - 03:04 PM
... I thought I saw a rec posted for new front load washers.
for what ?
so... what is your Error Code ?
You're not the first one to be confused (nor the last)
Frigidaire saved a few cents on diagnostic software programming :whistling:
#19 cannotfit
cannotfit
  • 13 posts
Posted 24 December 2011 - 03:44 PM
for what ?
I have this going on, too :(. Not a repair I want to tackle.
41 (and the original one was 47 NOT 43 as I thought). Had the new lock mechanism not been a dud I would have saved myself the cost of a new control board. But because of all the web searches (due to the control board and latch not fixing it), I found out about the spider corrosion problem. The random grease streaks the washer would leave on clothes just confirms to me that the bearings and spider will soon totally fail.
and on not buying short screws and on using aluminum instead of ss compatible metal and . . . . :(
At least it has lasted 6 years, but that is only 1/2 of what I expected. I should probably just make do with an apartment sized top load stackable set and buy a new machine when we move in another year. If I were a stronger person I'd probably get the new drum/spider and find some new bearings, but replacing the shocks just once was almost more than I could do.
Thanks again for the assistance.
#20 RegUS_PatOff
  • 30,255 posts
Posted 24 December 2011 - 06:05 PM
... I would have saved myself the cost of a new control board.
Buy your parts here! Posted ImagePosted ImageRead More :whistling:
Also tagged with one or more of these keywords: frigidaire, FTF2140ES1, front loader
