Kenmore Mod#25372242201 board bad?
3 replies to this topic
#1 deezus
deezus
    Kohai
  • Chief Appliantologist
  • 358 posts
Posted 24 December 2011 - 11:17 AM
This unit would cool, then get warm and stay that way. Changed out the start device/relay. Now , it got cold when i turned it on then it got warm again??? But now the compressor comes on and off, like compressor will run for awhile then turn off. Could this be the board??
help!!
    Shōgun
  • Master Samurai Tech
  • 29,800 posts
Posted 24 December 2011 - 11:33 AM
If the overload is still getting voltage when the compressor should be running but ain't, then one of three possibilities:
- bad overload, failing under load
- compressor is drawing too much current and tripping the overload, measure current draw
- bad relay, failing under load.
#3 deezus
deezus
    Kohai
  • 358 posts
Posted 24 December 2011 - 11:55 AM
I only replaced the Relay and plug # 5304468029 Does this have the relay and overload built in?
How do I measure current draw? And if it is drawing too much current would that mean a bad compressor?
He says now that he can hear compressor start and run every so often...like it will run for a few then stop.
#4 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 24 December 2011 - 01:06 PM
post Fridge and Freezer temperatures when they're warm
post a picture of the frost pattern of the Evaporator Coils in the Freezer
