Kenmore 665.15974 - Heating Element works to dry, but not wash?
Heating element
7 replies to this topic
#1 3ringcircus
3ringcircus
  • 11 posts
Posted 26 December 2011 - 04:54 PM
Very poor washing lately.
  • water level - good during washing cycle (it should be below heating element, correct?)
  • water temp - <110 F during washing cycle, I can touch heating element w/o any ouchy and as I understand, it should be 140 F?
  • after drying cycle, dishes are hot to the touch as they should be.
At first, I though a bed heating element, but since it works for drying, am I correct in assuming it's something else like a part that controls the element? And if so, do I need to check the CCU leads or heating wiring loop for continuity?
#2 RegUS_PatOff
  • 30,689 posts
Posted 26 December 2011 - 05:10 PM
Kenmore 665.15974
are there a few numbers missing ?
How's the Thermistor ?
... and Hi-Temp Wash is selected ?
#3 3ringcircus
3ringcircus
  • 11 posts
Posted 26 December 2011 - 05:25 PM
Do you mean numbers missing in the model #? Manual is for a Kenmore elite dishwasher and lists "Models 665.15972, xxx74, xxx79, xxxx73. I'm not really sure which mine is but guessed xxx74 because the label inside top says, "974456A" near the instruction stickers.
I don't have a "high temp wash" button; but manual list temps for normal wash which is the one we always used successfully as 140 F unless the soil sensor detects "light" in which case it doesn't boost water temp.
How do I test the thermistor?
#4 RegUS_PatOff
  • 30,689 posts
Posted 26 December 2011 - 05:56 PM
different model numbers have different Thermistors and possibly different Wash Options
#5 3ringcircus
3ringcircus
  • 11 posts
Posted 26 December 2011 - 06:03 PM
Sorry, looked closer, and found model number: 665.15972
#6 jumptrout
jumptrout
  • 1,192 posts
  • Flavorite Brew:Coors Light
Posted 26 December 2011 - 06:17 PM
Should be 8 digits after the period.
#7 3ringcircus
3ringcircus
  • 11 posts
Posted 26 December 2011 - 06:21 PM
apologies, one more time: 665.15972992
#8 RegUS_PatOff
  • 30,689 posts
Posted 26 December 2011 - 07:28 PM
665.15972992
Tech Sheet - 8051291.pdf
link PM'd
Thermistor 9743158
47KΩ - 53KΩ @ 25°C/77°F
12KΩ - 13KΩ @ 60°C/140°F
