KitchenAid built in oven KEBC107
KitchenAid KEBC107
4 replies to this topic
#1 Syclone
Syclone
  • 2 posts
Posted 26 December 2011 - 06:32 PM
Back when the time changed my wife attempted to reset the clock. She somehow has locked the screen but only with respect to the clock. We can use the oven just fine. Anyway, oven controls are all blank. Push clock and the correct time will display AND the word "start?" pops up over on the oven control side. Push cancel and the clock & "start?" both go away. If we just wait it will do it on its own. No amount of button pushing that I've found will allow the clock to display normally.
Side note: I thought that maybe she somehow activated Sabbath Mode but I can't get it to turn on of off either. Presumably it's in the off mode but with the door open as instruceted it won't let me do anything. Any button push just gets me 3 beeps is close succession.
As it happened we had a power failure a couple weeks ago for about 2 hours. Hoped that would help but no luck. Problem still exists.
Thanks.
Don
#2 RegUS_PatOff
  • 30,192 posts
Posted 26 December 2011 - 07:34 PM
KEBC107
missing (4) characters at the end of model number
Do you have the tech sheets for Sabbath ON/OFF ?
Have you recently used Self-Clean ? :nono:
#3 Syclone
Syclone
  • 2 posts
Posted 26 December 2011 - 11:28 PM
Thanks for the reply,
Last digits are: KSS03
Sabbath mode works as far as I can tell. I can get it to say Sabb on and then off.
So the problem, stated differently is:
1) Walk up to oven ALL displays are off
2) Press clock and it shows the time and within a couple of seconds the word "start?" appears on the oven display. Push clock start and everything, including the clock, goes blank.
#4 DurhamAppliance
    Sho' Nuff Chozin
  • 1,711 posts
Posted 27 December 2011 - 12:05 AM
Not sure if you tried this as it's not mentioned in your post but have you cut power to the oven for at least 10 minutes to see if it will reset itself?
#5 Budget Appliance Repair
  • 3,996 posts
Posted 27 December 2011 - 06:31 AM
Push and hold the clock button for about 10 seconds and see what happens.
I've can't recall every hearing of Whirlpool doing this but I do know some of the Frigidaire's have the option of the clock not displaying except when you push the clock key, then it will go out after 5 to 10 seconds. The option to put it into and out of this
mode is to press and hold the clock key until it beeps or something, (about 5 to 10 seconds), toggles option on/off.
Can't hurt anything to try it.
William Burk (Willie)
Eureka, CA 95501
Also tagged with one or more of these keywords: KitchenAid, KEBC107
