Frigidaire FRS23H5ASB8 has Intermittent Compressor
11 replies to this topic
#1 T Thump
T Thump
  • 6 posts
  • Flavorite Brew:Molson Canadien
Posted 27 December 2011 - 02:10 AM
I have a Frigidaire side by side that is just under 7 years old. For the past 8 months or so it will run fine for a couple weeks and then it gets warm on both sides. Turn it off for 8-12 hours and it starts working and will run again for another couple of weeks.
When the box is warm the evaporator and condensor fans are running and the compressor does the hum and click thing trying to start. A few weeks ago I replaced the start relay and the capacitor but the problem came back after a little over a week. The condenser fan and coils are clean. When the compressor is running, both sides stay at proper temperature until the next time the compressor stalls.
This morning the box was warm again(it's been 10 days since the last time). I turned off the refrigerator and about 5 hours later started it back up and it's working fine again. I am watching the evaporator coils in the freezer section, and they seem to be icing up with a thin film of frost over the entire evaporator. Earlier this evening I was able to feel the evaporator defrost heater getting warm when the unit was working properly and cooling.
As near as I can tell everything is working now until the next intermittent problem. What can I look at in the meantime, and what should I check the next time the problem comes back. Any ideas on what could be the problem?
#2 Budget Appliance Repair
  • 4,963 posts
Posted 27 December 2011 - 06:40 AM
I can pretty much guarantee you that the compressor is failing, bearings seizing up when the get warmed up.
I've seen the exact same problem/complaint on a SxS Frigidaire of a very similar model and vintage, (yours appears to be around a 2003 from the dates in the parts breakdown pictures).
Frigidaire's have a very bad track record on sealed system/compressor problems. I not surprised at all when I see a Frigidaire that is only a little over 6-7 years old failing because it's out of freon or the compressor is having problems, (mostly low on freon - I haven't had that many with actual failing compressors as you're experiencing).
William Burk (Willie)
Eureka, CA 95501
#3 jumptrout
jumptrout
  • 1,380 posts
  • Flavorite Brew:Coors Light
Posted 27 December 2011 - 07:44 AM
When this happens is the compressor hot to touch?
Is the condenser fan running full speed?
Is the dust cover in place at the compressor cavity?
#4 T Thump
T Thump
  • 6 posts
Posted 27 December 2011 - 10:59 AM
When the problem occurs the condenser fan is running at normal speed, the compressor is approximately 125-130 degrees(hot to the touch, but not too hot to leave my hand there comfortably). The dust cover is loosely in place. Problem occurs whether or not it is screwed down.
Update: The compressor is running this morning, the temperature in the beer side is 30 degrees, and there is a light film of ice on the the entire evaporator. All appears to be well for now, but I expect the compressor to do the hum click thing in a week or so.
The compressor is a Tecumseh that's made in Brazil. How much crappier can that get? Maybe if they had some goat lover build it in Turdistan? I used to sell industrial refrigeration systems and back then I had a lot of customers who refused to buy anything with a Tecumseh in it. I can't believe Tecumseh is still in the business. I noticed that one source for replacements sells Panasonic. Are those any good? I have been away for a while and didn't have a lot of experience with hermetics anyway.
#5 T Thump
T Thump
  • 6 posts
Posted 27 December 2011 - 11:03 AM
Refrigerator was new in April of 2005. I have been doing some research on the web, and yes, it appears that Frigidaire has a compressor problem with their products going back to around 2000.
#6 jumptrout
jumptrout
  • 1,380 posts
Posted 27 December 2011 - 12:25 PM
Your problem may be a defective ADC(defrost control board).
Intermittent problems are the reason I have no hair.
#7 T Thump
T Thump
  • 6 posts
Posted 27 December 2011 - 01:03 PM
The ADC has crossed my mind since replacing the starter and getting no joy. I can't seem to find any information on what it's supposed to be doing when it works right. It's the reason I am keeping a close watch on the frost buildup on the evaporator.
Someplace I think I saw reference to the idea that liquid refrigerant may be getting back to the compressor because the ADC isn't working right. Wish I could find it and post a link. Seemed like it was a source of a lot of problems if not in Frigidaire, but in some other makes as well.
#8 jumptrout
jumptrout
  • 1,380 posts
Posted 27 December 2011 - 01:21 PM
The defrost control serves 2 main functions.
1.send power to the compressor.
2. send power to the defrost system.
After defrost the adc times out to send power back to the compressor.
They can act intermittently due to a defective board or loose or corroded wire terminals.
The cold control can also be intermittent in operation.
Your compressor runs days at a time with no issue.
My focus would be on the 2 parts discussed above.
#9 T Thump
T Thump
  • 6 posts
Posted 27 December 2011 - 01:52 PM
The name implies that it "adapts" to something. Any idea what it is "adapting" to? I suppose it could cause problems if it doesn't "adapt" correctly.
Side observation, not necessarily related to the ADC, one of the recent compressor lock ups occured at the same time we had a 3 hour power failure during a windstorm.
I think I need to do some focused research on this ADC module.
#10 T Thump
T Thump
  • 6 posts
Posted 27 December 2011 - 02:00 PM
Jumptrout, regarding your hair, I was a field tech and did industrial machinery repair a long time ago. In all my years I never saw an intermittent occur when i was within 50 feet of a control cabinet with a multimeter in my hand.
...but just walk to a break room and pick up a cup of coffee...
#11 Comstock_Services
Comstock_Services
  • 462 posts
Posted 27 December 2011 - 05:48 PM
its adapting to the moisture, humidity, number of times the doors opened, and the compressor run times, But thats just me pulling something outta thin air.
If the ADC is intermittent, the check for heavy frost on the evap, when the failure occurs, also check to make sure you've got power to the compressor, when its doing the buzzing bit. I would also do and amp draw on the compressor when it's doing the buzzing thing, if it's close to the LRA number, its proably bad. The little blue indian is no ones friend.
#12 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 30,176 posts
Posted 28 December 2011 - 09:23 AM
Part link ==> ADC board and kit
