Kenmore 90 Series Washer M/N 110.22922100 won't spin without 'help'
#1
Posted 27 December 2011 - 11:05 AM
Any help on pinpointing the offending part(s) would be greatly appreciated.
#2
Posted 27 December 2011 - 04:45 PM
- Comstock_Services and wvhcrash like this
#3
Posted 27 December 2011 - 05:58 PM
part number 5 is the clutch. http://www.repaircli...er=110.22922100
Edited by Comstock_Services, 27 December 2011 - 06:00 PM.
- Samurai Appliance Repair Man, kdog and wvhcrash like this
#4
Posted 28 December 2011 - 02:10 AM
#5
Posted 28 December 2011 - 08:50 AM
The Hand Test for the Clutch
If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test.
WARNING: This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a bloody death. Proceed at your own risk! Have a nice day.
- put the timer on a spin cycle and open the lid
- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand
- turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin
- if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand
- if it takes very little force to stop the tub from spinning, the clutch needs to be replaced.
The Clutch Eyeball Test
The Eyeball Test is less risky than the Hand Test but requires lots more time and mechanical fiddling. It’s not as comprehensive as the Hand Test because it only checks for one particular defect with the clutch. But it’s included here for your edification.
Use a pair of pliers to compress the spring of the clutch ring and remove it from the drum. Inspect the rivet holes that hold the pads to the ring. If these holes are packed with debris, then change the clutch. When a clutch is slipping, as well as any other frictional surface, it will develop a glazed look to it which will reflect light and look glossy, just like a lawnmower belt or washer drive belt that has been slipping. This can cause for a burnt rubber or plastic smell.
You don’t need to remove the outer tub to inspect the clutch drum and ring; all you need to do is remove just the gear case. This saves lots of time and headache and keeps the water seals intact and undisturbed.
Part link ==> clutch kit
- kdog and Comstock_Services like this
#6
Posted 28 December 2011 - 11:40 PM
Also tagged with one or more of these keywords: kenmore washer, 110.22922100, spin
