Scottsman Ice Machine DCE33A-1WB
No frost on evaporator
3 replies to this topic
#1 Comstock_Services
Comstock_Services
  • Appliantologist
  • 462 posts
Posted 28 December 2011 - 08:55 PM
I've got a scottsman ice machince that will cycle properly, but will not form ice in the evaporator. I was wondering what temp the unit should be at to make ice? I don't work on many of these, but it seems to me that there is an issue with the cube size control. I say this because the water cools down to about 37-38f.
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,928 posts
  • Flavorite Brew:Killians Red
Posted 29 December 2011 - 06:44 AM
Pull one of the hoses off the circ pump and let the water drain out of the reservoir...then turn it back on to a freeze cycle...
The evap cups should frost completely in about 5 minutes. If not, sealed system problem.
Problems with the cube size control usually result in short cycling...the unit will not pause for the "freeze" cycle...timer continuously runs.
Also see that the water valve is not leaking thru...constant inflow of tap water will not allow unit to freeze in a timely manner.
Average freeze time per cycle 22-25 minutes...
#3 jumptrout
jumptrout
  • 1,382 posts
  • Flavorite Brew:Coors Light
Posted 29 December 2011 - 06:59 AM
Clean the condenser.
Check the condenser fan.
Feel the hot gas valve line for leaking by.
Clean the spray nozzles.
#4 Comstock_Services
Comstock_Services
  • Appliantologist
  • 462 posts
Posted 29 December 2011 - 10:14 AM
ok the line tap is on its way, thanks for the Ideas guys.
