Maytag MLE2000AYW Stack W/D Leaking Out Washer Door
MLE2000AYW leak softener
13 replies to this topic
#1 jamichau
jamichau
  • 13 posts
  • Flavorite Brew:Alaskan Amber
Posted 29 December 2011 - 02:43 AM
Honorable Masters of Repair,
My now 10-year-old Maytag stacked W/D began infrequently and mysteriously leaking water out the door more than a year ago. Nowadays, however, it "has an accident" nearly every load of laundry. The problem appears to be with the fabric softener (FS) dispenser. Although sometimes the dispenser will be left full of water at the end of a cycle when there has been no leakage, the dispenser cup is always left full of water at the end of a cycle during which there is a leak (thank God for concrete slab construction!). It seems odd that the FS cup is ever left full, as it has a "port" in the side through which the FS is dispensed into the tub when water floods the cup and creates a siphon, supposedly emptying the cup. When the cup is left full, there is no sign of the FS, just plain water. I found a previous post on this same subject from 2008 here: http://appliantology...__1#entry90298.
When I discover the FS cup full of water, I can lift it up and it will begin to drain immediately. If I take it to a sink and fill it with water, the siphon works and the cup empties itself. I have removed all parts from the FS dispenser and cleaned them, but the problem persists. There have been signs of sticky FS goo buildup in the bottom of the cup, but I have cleaned all that.
I just went to the washer to do a manual test. The FS cup was already full of water, the aftermath of the most recent leak just few hours ago. I lifted the cup and, sho'nuff, it began to drain (the water leaves the cup and drains all the way down into the bowels of the washer). I grabbed a cup of water and poured it into the FS cup until nearly full. No siphon. I picked up the cup, siphon. I took the cup to the sink, filled it until the water was about half-way covering the drain port, no siphon. I then filled it completely to the top and the siphon started. I filled it nearly full again and just lifted slightly on the insert that covers the siphon tube(has the words Fabric Softener on it) and the siphon started. Hmmm. I notice that I can sometimes start the siphon by filling the cup right to the very top while it's in the washer, as occurred when I filled it at the sink. So maybe the washer is filling the cup normally, but the late start on the siphon is causing the leak? I don't know.
The previous post, from Kendal, revealed no resolution. I'm hoping someone will possess, and share, the knowledge which will free me from mopping up after my washer every cycle.
Many appreciative thanks in advance for any assistance,
-J
#2 nickfixit
nickfixit
  • 1,990 posts
  • Flavorite Brew:Glen Livit
Posted 29 December 2011 - 06:52 AM
The hose from the bottom of the dispenser to the lower tub may be plugged or restricted. The siphon action would stop when the tube fills up, and any added water would overfill the reservour.
#3 jamichau
jamichau
  • 13 posts
Posted 29 December 2011 - 10:27 AM
Thanks for the reply, Nickfixit. When I remove the FS cup and pour water directly into the remaining void, the water drains straight away, so the hose doesn't appear to be obstructed. How can I check the hose further? Thanks again.
#4 Budget Appliance Repair
  • 4,032 posts
Posted 30 December 2011 - 07:01 AM
Sounds to me like the top siphon cap isn't fitting correctly or your really haven't removed all the fabric softner scum buildup in the top of the siphon cap tube, (the part about raising the cap portion and the siphon starts says the cap is going down too far plugging the siphon tube off or buildup that plugs the siphon tube when cap is seated down in place).
William Burk (Willie)
Eureka, CA 95501
#5 AvanteAppliance
AvanteAppliance
    Ikkō-ikki
  • 47 posts
  • Flavorite Brew:Miller Lite
Posted 31 December 2011 - 02:42 AM
Check and make sure cho door isn't misaligned as well, the door boot and door should be sealing properly to prevent any leaks.
"Get crunk with it get loose with it, my clients don't care as long as your @$$ fixes it."
#6 jamichau
jamichau
  • 13 posts
Posted 07 April 2012 - 12:28 PM
Well, the battle rages on. I ordered a new FS cup from this website in January, not OEM, but nearly identical. Didn't help. I've taken video of the overflow action with the door open and will upload. It should be available from this discussion, I think, once it's uploaded in a few minutes. Right now, I'm leaning toward Nickfixit's idea of checking the FS drain hose. Can't think of any other ideas, unless someone else has a new idea. Many thanks, in advance, for any additional opinion.
-J
#7 jamichau
jamichau
  • 13 posts
Posted 07 April 2012 - 12:46 PM
OK, so I can't figure out how to upload a video (if it's even possible). When replying, I see the button called My Media which leads to "Your Media Library", but I see now way to add media. I'm assuming this would require paid subscription, yes? Can anyone enlighten me? Thanks!
#8 RegUS_PatOff
  • 30,708 posts
Posted 07 April 2012 - 12:55 PM
post to YouTube, then post link here
#9 jamichau
jamichau
  • 13 posts
Posted 07 April 2012 - 01:59 PM
First video uploaded to YouTube:
#10 jamichau
jamichau
  • 13 posts
Posted 07 April 2012 - 03:04 PM
Second video:
#11 kdog
    RoughShod
  • 7,433 posts
Posted 07 April 2012 - 07:43 PM
Yup - I believe Nick nailed this first time out - didja see that manual over in the downloads section ?
http://appliantology...ectric-mle2000/
#12 jamichau
jamichau
  • 13 posts
Posted 17 April 2012 - 10:52 PM
SOLVED! Nikfixit and KDog got it right: clogged drain tube from FS cup. I thought about their proposition for awhile and decided that if they were correct, partially clogged drain tube, I'd handle it just like a slow sink drain: CHEMICALLY. I removed the FS cup and basket, poured about 8 ounces of Drano Max Gel down its gullet, waited 30 minutes, and flushed it with 4 cups of hot water. Then, with the washer empty, I set the timer to the 3rd rinse to test and flush the Drano and hit the start button - NO leak! Then I washed a load of laundry, no leak. Hasn't leaked in a little over a week. I'm glad it was simple and I appreciate the wise words of those more experienced than I. Much gratitude to you.
-J
#13 Budget Appliance Repair
  • 4,032 posts
Posted 18 April 2012 - 06:54 AM
I don't think Drano is really the best thing to be putting into a washer to clear clogged rubber tubing?
Eureka, CA 95501
#14 AvanteAppliance
AvanteAppliance
    Ikkō-ikki
  • 47 posts
Posted 18 April 2012 - 11:33 AM
ROFL!!!
