Grasshoppers should be encouraged to post repair follow up
Maybe some reminder or encouragement for posters to provide a follow up . Many times the poster may have a strange or unusual problem where the resolution of such problem can help masters in future diagnoses. The info could be invaluable. Maybe some pledge to post accurate model numbers and to post a follow up could be a requirement before having the privilege to post.
Egzzelent suggestion, Brother Durham. I'm going to look into having a little pledge added to the sign up page that they have to check to continue registration.
A good idea---though impossible to enforce.
With *closure*---much can be learned about appliance faults and the solutions to them.
There's a certain percentage of visitors to the forum that do the following...
APOLLO 13: "Houston, we have a problem."
HOUSTON: "Try flipping switches 6 & 9 on fuse buss number two."
APOLLO 13: "Stand-by"
<<<<<silence>>>>>
:turned:
  • Like 3
Just appeal to their sense of honor. Get free info...how 'bout giving something in return.
