Whirlpool Duet dryer GEW9200LW1 not drying completely
#1
Posted 31 December 2011 - 01:08 AM
#2
Posted 31 December 2011 - 01:13 AM
all you need is heat (you say it's good)
and air-flow / vent (you say it's good)
OR possibly your Washer isn't Spinning the water out completely.
check your Venting System
Dryer Vent
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
- kdog likes this
#3
Posted 31 December 2011 - 04:02 AM
#4
Posted 31 December 2011 - 08:20 AM
You may want to check your element for a break ,maybe weldded to to the can, running on half vaoltage...
Double check the entire vent system, including interally of the dryer, especially the filter chute...
Please report the cycling temps at the vent outlet with the unit empty, on normal high heat...
Sure sounds like a vent issue...
#5
Posted 01 January 2012 - 08:25 PM
#6
Posted 01 January 2012 - 09:31 PM
#7
Posted 01 January 2012 - 10:56 PM
