First no ice, now no water - Frigidaire FRS26ZSGB4
2 replies to this topic
#1 pcking
pcking
  • 6 posts
Posted 04 January 2012 - 06:53 PM
Have a Frigidaire FRS26ZSGB4 that has been in loyal service for about 12 years with very few issues.
Recently, the ice maker started to make less ice and eventually stopped altogether.
Around a month later, I started noting a loud buzzing while trying to dispense water and now that function no longer works either.
After poking around the forum for a while, I found that the likely culprit is the water inlet valve, but my luck it appears there are two of them on this unit and they are around $50 apiece.
Water Inlet Valve
Item #452252
Water Inlet Valve
Item #452316
So, based on the description above, whioch one should I replace first? Or is there a good way to isolate the faulty one?
The second one seems the be the primary valve, witht the first is the secondary, so I'm thinking #452316 is my best bet, but I hate just swapping parts and praying...
Thanks! -Phil
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 04 January 2012 - 07:00 PM
... Recently, the ice maker started to make less ice and eventually stopped altogether.
... is there a good way to isolate the faulty one?
1) Freezer needs to be at +15F or colder for the IceMaker to work
2) water lines may be frozen somewhere ...
disconnect output of either Water Valve and have a bucket ready to catch the water while activating the Valve
There's also Diodes in the Water Valve circuits
see bottom left of page 2
218902000.pdf
tech sheet
link PM'd
#3 pcking
pcking
  • 6 posts
Posted 04 January 2012 - 09:18 PM
Thanks for the guidance - I just printed the schematic and will give it whirl.
