Maytag SAV5910 AWW Leaking - How do I get past removing the inner tub?
9 replies to this topic
#1 milkman
milkman
  • 2 posts
Posted 01 May 2005 - 05:35 AM
Leaking is almost certainly at the plastic tub seal.   However, I can't get the "flange" that the stainless steel tub is mounted on to budge.
    Shōgun
  • Master Samurai Tech
  • 30,578 posts
Posted 01 May 2005 - 06:59 AM
You need a spanner wrench.
#3 milkman
milkman
  • 2 posts
Posted 01 May 2005 - 07:04 AM
This spanner wrench would appear to be a special design that is machined to fit the pattern on the top of the hub.   Will a "regular" spanner wrench damage this hub?   Shouldn't I be able to accomplish the same thing by putting the four bolts and the stainless tub back in place and using the tub as my leverage?   It doesn't appear to do so!    I see that it is not really a special design, other than dimension.   Does the removal of this hub require a hammer to move the wrench, as well as the wrench?
    Shōgun
  • 30,578 posts
Posted 01 May 2005 - 05:24 PM
Yes, it's specially designed to fit that nut. It is designed to be used with a hammer to tap the nut loose.
#5 Budget Appliance Repair
  • Senior Appliantology Fellow
  • 5,024 posts
Posted 01 May 2005 - 11:50 PM
Samurai, that looks lots like an Amana/Speed Queen washer....
When did Maytag buy out Amana/Speed Queen or I'm I totally mistaken?????
William Burk (Willie)
Eureka, CA 95501
    Shōgun
  • 30,578 posts
Posted 02 May 2005 - 04:19 AM
Maytag bought 'em out 2 or 4 years ago.  I remember when it happened, Maytag announced that the monthly service subscription CD would start including Amana stuff.
#7 denrayr
denrayr
  • 1,146 posts
Posted 02 May 2005 - 06:52 PM
This washer is a piece of garbage. tons of middle seal failures. call maytag and bitch, tell them that you went online and found out a lot of people are having the same problems. it cant hurt.
:cool:
#8 Mad Mac
Mad Mac
  • Appliantologist
  • 1,444 posts
Posted 02 May 2005 - 07:33 PM
About 4 years ago, I was still at S***s at the time.
Mad Mac....Pray to God he's out there....somewhere.
#9 jrhexp
jrhexp
  • 5 posts
Posted 16 May 2005 - 04:25 PM
Thanks for the great info. I have a spin cycle leaking SAV5401AWW that I bought (Mistake) about 2 years ago could it be the same problem?
#10 Lurker_billy_*
Lurker_billy_*
  • Lurking at the Threshold
Posted 18 May 2005 - 05:31 AM
fill the tub with gas and burn that piece of crap.  I've done about fifty seal kits in six months.  Maytag- you stink!
