Appliancejack
Kenmore washer Model 110.26432503
3 posts in this topic
This washer runs good for months at a time and all of sudden it stops after it fills. Will not agitate,drain, or spin. It will run through a few cycles and make a loud buzzing sound while trying to go into drain and spin. Next a clicking noise from the motor happens and the washer will do nothing for about an hour and all of sudden starts back up draining and then spinning. Lid switch has been changed and motor coupling is fine. Any thoughts?
Smells like the timer to me, trying to energize the motor in forward & reverse at the same time.. then the motor gets hot and cuts out. Next time the washer is trying to spin, try pushing the timer in and pull it out again a few times, or smack the timer. Also inspect the contacts on the motor.
Timer part link ==> Part number: AP3855066
