Broiler won't turn off on Kenmore Oven Model 665.95824001
Broiler kenmore oven 95824001
8 replies to this topic
#1 tkelly5
tkelly5
  • 4 posts
Posted 05 January 2012 - 10:23 PM
Help! The broiler on our oven will not turn off, we have to turn it off at the breaker.  There are no error messages or anything unusual, other than the broiler not turning off. We've tried letting it sit for a while and turning it back on but it still will not work.
It isn't one of the recalled models.
Help!
#2 RegUS_PatOff
  • 30,261 posts
Posted 05 January 2012 - 10:38 PM
can you check that model number again ?
are there another (3) digits before that number ?
maybe 665. ?
If so, the Broil Element may be partially shorted to chassis (ground)
OR the Controller may be bad.
Have you recently used Self-Clean ? :nono:
#3 tkelly5
tkelly5
  • 4 posts
Posted 06 January 2012 - 07:29 PM
Yes, there is a small 665 followed by 95824001. Haven't used the self-clean in 6 months.
#4 RegUS_PatOff
  • 30,261 posts
Posted 06 January 2012 - 07:33 PM
... a small 665
... made by Whirlpool
If the Broil Element is shorted to chassis, it can be tested with a meter.
  • 24,296 posts
Posted 06 January 2012 - 09:07 PM
Topic title edited.
#6 guido163
guido163
    Ikkō-ikki
  • 32 posts
Posted 07 January 2012 - 08:52 AM
I just fixed this on my "whirlpool" 665.95812000. I replaced two relays in the control board.
  • 24,296 posts
Posted 08 January 2012 - 05:55 PM
If the element isn't shorted to ground, then you're looking at a bad ERC.
Part link ==> http://www.repaircli...er=665.95824001
#8 tkelly5
tkelly5
  • 4 posts
Posted 08 January 2012 - 06:04 PM
How do I test it with the meter to see if it is shorted?
How can I tell if it could be the relays?
#9 RegUS_PatOff
  • 30,261 posts
Posted 08 January 2012 - 07:01 PM
disconnect the Power Cord and set your meter for 200 OHMs and measure between either end of Broil Element to chassis (ground)
http://fixitnow.com/...tion-making.htm
testing the Relays is more difficult, but it you do find a bad Relay,
you'd either have to replace the Controller,
or know how to solder to remove and replace the Relay.
Also tagged with one or more of these keywords: Broiler, kenmore, oven, 95824001
