rymice
Whirlpool dryer won't spin or heat LEQ8621PW0
7 posts in this topic
Appliantologists,
My daughter called and said her Whirlpool electric dryer LEQ8621PW0 would spin but was not drying. I pulled the unit from the wall and laid it on its back. Removed the front cover. I did a continuity check on the heater element and it showed open. I unplugged the hi limit thermostat and thermal cut off and removed the heater box with the element. I removed the element from the heater box and verified the coil was defective.
I replaced the element. Reassembled the dryer and when I plugged it in, nothing! No spin or heat. I have 240 VAC at the receptacle. I can hear the timer running when I attempt to run the dryer. I can hear the timer stop when I open the door and restart when the door closes. I have continuity across the thermal fuse contacts. Where do I go from here?
Rymice
Edited by Samurai Appliance Repair Man
Increased font size so I could read it!
Ah, This Is Embarrassing,
just talked to my daughter and she schooled me on how to run the dryer! How was I supposed to know that you have to turn the dryer signal switch to on and push in! Not very intuitive. The dryer is working fine and I’m open to abuse. Thanks
Rymice
It appears you have beaten yourself up an appropriate amount already so I will refrain from adding to your slugfest...
I like someone who's not afraid to admit their mistake :)
Oy! Never a good idea to do this to an appliance unless the appliance is specifically designed to be serviced this way... and this dryer ain't. So there's no telling what may have happened inside the dryer when it was laid on it's back. You're gonna need to open her up and checking the wiring.
On this one, all's you gotsta do is...
Remove the front kick panel to reveal the bottom retaining screws for the door panel. Now remove the top panel to reveal the top retaining screws for the door panel. Disconnect the wiring harness for the door switch and remove the door panel. Now unstring the belt and remove the drum.
Source ==> http://fixitnow.com/...er-disassembly/
I have worked on like 25,000 washers and dryer believe me I have done far dumber things then that LMAO :wallbash:
I've actually forgot to reconnect the door switch so I feel ya there brother. That's why I live by the K.I.S.S rule!! Keep It Simple Stupid...lol But Hey YOU FIXED IT RIGHT!!!?? GOOD JOB!;)
Edited by phydeauxe64
I can beat you I have replace a pump put it back together again and find it not pumping only to realize I forgot to remove the hose clamp pliers :banghead:
