Oven door won't shut properly Whirlpool SF305PEEN
7 replies to this topic
#1 odrina
odrina
  • 2 posts
Posted 07 January 2012 - 11:46 AM
Hi, I have a Whirlpool SF305PEEN, and the oven door won't shut properly (it was open all the way down, and I fell on it...ouch...). What do you think is the problem, and how can I fix it? Maybe the springs? It seems like there is no more tension, before, when the door was half shut, if I let it go, it will shut on it's own...not anymore...
Thank you
    Shōgun
  • Master Samurai Tech
  • 30,526 posts
Posted 07 January 2012 - 02:26 PM
You need to replace both hinges on the door. The spring is built into them. To install, remove the door and disassemble it to install the new hinges.
Hinge part link ==> Part number: AP3038786
#3 Chat_in_FL
Chat_in_FL
    Havoc
  • 1,521 posts
  • Flavorite Brew:What's on tap?
Posted 08 January 2012 - 08:07 AM
Samurai, looking at those hooks on the above-pictured hinges -- what do they hook onto? I dont see hinge receivers on the parts list, and would suspect that the pins these hinges hook onto may be damaged as well?
Mother Teresa
The views and opinions expressed in this post are those of the author and do not necessarily reflect or represent the views and opinions held by my employer. All data and information provided is for informational purposes only.
Big Brother
#4 jumptrout
jumptrout
  • 1,382 posts
  • Flavorite Brew:Coors Light
Posted 08 January 2012 - 08:53 AM
The hinges latch on to pins in the oven frama and are most likely not bent.
The springs are sprung.
#5 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 08 January 2012 - 09:13 AM
#6 odrina
odrina
  • 2 posts
Posted 10 January 2012 - 02:27 PM
Hi, thank you ALL for the answers! Yes, Samurai, you are right, the springs should be attached inside, because I looked for them, but I couldn't find them, since they are inside the door...I'll order the hinges then.
Thx also for the pictures, fortunately, since I was the one who bought the stove, I stil have the booklet with the instructions, so I was able to remove the door, and put it back.
#7 Chat_in_FL
Chat_in_FL
    Havoc
  • 1,521 posts
Posted 11 January 2012 - 06:57 AM
You're probably correct, I just tend to look a little deeper when I hear those words "I fell on it."
Mother Teresa
Big Brother
    Shōgun
  • 30,526 posts
Posted 11 January 2012 - 10:38 AM
I hear you-- good thinking, Brother Chat!
