Frigidaire GLHS36EFSB0 Defrost issue.
Frigidaire defrost control
2 replies to this topic
#1 mrjtwright
mrjtwright
    Yamabushi
  • 88 posts
  • Flavorite Brew:Samual Adams
Posted 08 January 2012 - 10:58 AM
I've inspected this refrigerator that is clearly not defrosting. the heating element tests good and so does the defrost t-stat switch. I'm assuming that this unit needs this new control board (as it does not have a stand alone timer). Does this sound accurate?
Oh, I also tried depressing the light switch 6 times to manually enter defrost mode. This was unsuccessful.
Thanks in advance
JT
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 08 January 2012 - 01:06 PM
... assuming that this unit needs this new control board
... tried depressing the light switch 6 times to manually enter defrost mode. This was unsuccessful.
sounds like a bad Controller
    Shōgun
  • Master Samurai Tech
  • 30,942 posts
Posted 08 January 2012 - 08:09 PM
Yep, on this box, if the def. heater, def. tsat, and wiring are good, then the only thing left if the Genesis board by default.
