ctj73
Kenmore Elec. Dryer Model # 110.87562602 Nothing happens when I hit the start button
9 posts in this topic
I was given this dryer cause it didnt work and i feel that I can fix it. All of the buttons and lights work except when you push the start button, nothing happens. What could this be. I have the control panel off and nothing "looks" burned or out of ordinary.
If it is powering up three things to check first
1. Door switch
2. Thermal fuse
3. broken belt (has a belt switch)
2 people like this
The door switch is clicking when pushed. the belt is on and spinning the drum freely by hand. Need help on the Thermal Fuse.
Thermal fuse is the white fuse on top of the blower housing with two wires going to it .. You can use a meter to check continuity or just put the wires together make sure not touching anything then plug in and try to start it (MAKE SURE IT IS UNPLUGGED FIRST)
http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986
2 people like this
Check for continuity on door switch and thermal fuse. Thermal fuse is the white usually about 1" long fuse attatched to the blower housing. Also check push to start or turn to start switch for cont. as well.Make sure it opens and closes.
Edited by phydeauxe64
2 people like this
Part links:
Thermal fuse ==> Part number: AP3132867
Door switch ==> Part number: AP4588360
1 person likes this
It is just the thermal fuse. On my way to get a new one. Thanks guys! Very much appreciated! :rocker:
1 person likes this
check your Venting System
Dryer Vent
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
