Tom Atkins
Insufficient cooling in Samsung RS2578BB refrigerator section
7 posts in this topic
Hi
We have this Samsung side by side referigerator RS2578BB. About 12 days ago, we returned from a vacation to find a puddle of water under our fridge and that it was off as the breaker switch for the fridge in the electrical panel had tripped. I reset the breaker switch in the electrical panel and it seemed fine since.
2 days ago , we noticed that the fridge side temperature LED was blinking and that the cooling inside the fridge side was insufficient. The freezer is still operating fine.
On forum postings for other Samsung refrigerator, we found a section on doing a "self diagnostics in the normal operation" by pressing Power Freeze and Power Cool together for 8 seconds till we heard a beep. At that point we saw that
Fridge temp 2nd digit's middle horizontal LED was lit.
We would appreciate any help in determining what the problem is.
Tom
... the breaker switch for the fridge in the electrical panel had tripped.
... Fridge temp 2nd digit's middle horizontal LED was lit.
1) is it a GFI Breaker ?
2) REFRIGERATOR DEFROST ERROR
check the Defrost Heaster with an OHM meter
1. The breaker is not a GFI breaker. It is a normal 20Amp breaker.
2. How would I access the Defrost Heater? To check with ohm meter - what would be the working range for ohms reading for a good defrost heater?
Tom
Hi, can you help with the steps on how to get to the defrost heater?
Tom
Defrost Heater # 52 may be about 120 OHMs
in the Fridge behind # 28, # 30, # 32
Hi, to get 28 out , it seems I would also need to remove the Cool Select Zone Drawer. Relating to schematic posted, this drawer is below 24 but above 18 and attached to 28. I already remove the plastic bin that was fitting inside this drawer already. The drawer seems a total unit with its own left, right and rear "walls" and seems drawer itself needs removal to get 28 out.
This drawer has electrical connections (I peaked from above at the back right corner and see wires going into the drawer), as well as additional small vents coming into the top of the drawer.
Would you be able to advise on how to remove this drawer?
Tom
Yes, and you'll have to remove the water tank. Here's Le Procedure from Le Manuel:
1. Pull out the screw cap and remove the screw.
2. Remove the lamp cover by unlocking the tabs
and pulling the cover down.
3. Remove the water tank from the evaporator cover
by unscrewing the screws (2).
4. Remove the screws (6) at the evaporator cover
and the two fixed screws of the wire connector
cover.
5. Take off motor and lamp wire connector located
on the upper liner.
6. Remove the duckwork of the evaporator fan.
