Sub Zero 632 No Lights
13 replies to this topic
#1 Oberg
Oberg
  • 7 posts
Posted 09 January 2012 - 07:29 PM
I have a 10 year old sub zero 632 side by side. All of the lights went out. The refer and freezer still woork fine - everything is cold and to correct temp but the lights in both the freezer and refer stopped working as well as the temperature display panels. I have cycled the on/off several times.
#2 RegUS_PatOff
  • 30,221 posts
Posted 09 January 2012 - 08:26 PM
600 series serial numbers
600-1 Prior to Serial #1810000
600 Addendum For units starting with serial #1810000
600-2 Built-In Approximate Starting Serial #2127000
600-3 Built-In Starting Serial #2600000
  • 24,258 posts
Posted 09 January 2012 - 11:18 PM
Oberg, what is the serial number of your unit?
#4 Oberg
Oberg
  • 7 posts
Posted 16 January 2012 - 10:27 AM
Serial number M1666719
Model # 632/0
M1666719 Model 632/0
#5 RegUS_PatOff
  • 30,221 posts
Posted 16 January 2012 - 01:11 PM
It looks to me that the only thing in common is the Controller 4202800
but I don't know why if everything else is working ..
unless there are burned traces on the back of the board ...
#6 jumptrout
jumptrout
  • 1,132 posts
  • Flavorite Brew:Coors Light
Posted 16 January 2012 - 05:34 PM
If this unit is in Sabbath Mode the lights do not work.
#7 Oberg
Oberg
  • 7 posts
Posted 16 January 2012 - 05:54 PM
What is the Sabbath mode?
  • 24,258 posts
Posted 16 January 2012 - 06:03 PM
Your owner's manual explains that in detail.
#9 RegUS_PatOff
  • 30,221 posts
Posted 16 January 2012 - 08:29 PM
SABBATH MODE (STAR-K )
All Built-In units feature the Sabbath Mode.
This is for certain religious observances where the lights and ice maker function need to be turned off.
To initiate Sabbath Mode, while the unit is on press the UNIT ON/OFF key pad so that OFF is visible in the Control Center display panel.
Your unit will be off.
Then press and hold the UNIT ON/OFF key pad for 10 seconds.
This will turn the unit back on and will disable the lights and ice maker.
To return the unit to normal operating conditions,
press and release the UNIT ON/OFF key pad.
#10 Oberg
Oberg
  • 7 posts
Posted 25 January 2012 - 01:10 PM
The unit is not in Sabbath mode. There are no lights even after cycling the on/off button.
#11 RegUS_PatOff
  • 30,221 posts
Posted 25 January 2012 - 02:33 PM
bad Controller
OR wiring
#12 Oberg
Oberg
  • 7 posts
Posted 25 January 2012 - 03:14 PM
Is this a DIY project? Can I purchase the part?
#13 RegUS_PatOff
  • 30,221 posts
Posted 25 January 2012 - 03:28 PM
The Controller may be bad OR the wiring
Controller part number may be 4160902
I don't know who sells Sub Zero parts anymore
The connections on the Controller could possibly be by-passed.
(Sabath Mode would no longer work)
#14 woftam
woftam
    Ikkō-ikki
  • Master Appliantologist
  • 28 posts
  • Flavorite Brew:red wine
Posted 25 January 2012 - 04:57 PM
Have you checked for voltage at socket or door switches? When you open door dose the evap fan still run?
There is a huge difference between 10 years experience and one years experience ten times over.
