if i was to buy a new washer kenmore 110 13212200 possible bad transmission
5 replies to this topic
#1 illpapa2k1
illpapa2k1
  • 6 posts
  • Flavorite Brew:coors
Posted 09 January 2012 - 07:53 PM
if i was to buy a new washer what would you wonderful appliantologist suggest. i visited the home depot only to discover that if i buy a washer most of them are belt driven and need to use H e detergent. not only are they not direct drive like my kenmore but i dont understand why i cant just buy a washer and use the frikkin detergent i got already. the salesman also informs me that most of us that buy a new washer need service 3 times in the first year! uuuugggh
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 09 January 2012 - 08:35 PM
... and need to use H e detergent. not only are they not direct drive like my kenmore
... but i dont understand why i cant just buy a washer and use the frikkin detergent i got already.
government water and energy conservation ...
Are you looking for a Top Loader OR a Front Loader ?
Direct Drive Top Loaders are still around (for a while)
There are some direct drive front loaders
#3 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 09 January 2012 - 08:50 PM
You may not find one quite the same as you have - the toploading (w/direct drive transmission) has been phased out, there still may be some around in stocks, but they will be more "H.E." than the one you have (modified fill levels/ rinse temp selections etc). The Frontloading "direct drive" technology refers to the fact that the outer tub itself in effect becomes the stationary poles of the motor; thus it drives the drum directly and is also beltless.
Personally, I wouldn't think twice at rebuilding my topload direct-drive.
#4 john63
john63
    Dean of LG Appliantology
  • 2,218 posts
Posted 09 January 2012 - 09:08 PM
<<<i visited the home depot only to discover that if i buy a washer most of them are belt driven and need to use H e detergent.>>>
Only top loading washers *without* an agitator require "HE" (High Efficiency/LOW SUDS) type detergent.
None are belt-driven (Direct drive).
LG
Samsung
Whirlpool
Maytag
Kenmore
GE
<<<i dont understand why i cant just buy a washer and use the frikkin detergent i got already>>>
Top load ***agitatorless*** washers use a fraction of water compared to top load washers that use an agitator.
A *low-suds/suds inhibiting* type detergent is **required** in order for the laundry to become clean in a washer that uses very,very small amounts of water.
<<<the salesman also informs me that most of us that buy a new washer need service 3 times in the first year! uuuugggh>>>
If the saleman was describing 3 warranty calls per year---because he neglected to inform his customers that using HE detergent in the following amounts is IMPERATIVE...
HE: (2) Tablespoons Per Washload (regardless of load size)
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
He's problably correct :)
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#5 illpapa2k1
illpapa2k1
  • 6 posts
Posted 10 January 2012 - 08:47 PM
im looking for a top loader, and when i diagnose my current machine ill fix it hopefully.
#6 RegUS_PatOff
  • 33,588 posts
Posted 10 January 2012 - 11:20 PM
http://appliantology...back-to-249-ea/
