Dryers With Moisture Sensors
Dryer Will Not Dry Small Load
4 replies to this topic
#1 john63
john63
  • 1,411 posts
Posted 10 January 2012 - 02:30 AM
I've been reading the previous 50 or so posts tonight---and noticed several visitors to the forum had a common "problem" with their dryer---which uses a MOISTURE SENSOR.
The complaint was identical:
"Laundry doesn't always dry" (and the vent system was ruled-out)
The responses were similar:
"Avoid small loads in dryers that have/use MOISTURE SENSORS"
or...
"For small loads---use the TIME DRY cycle"
There is a solution---and it's a very simple one.
Some years back---I had an older lady (widow)---that contacted us regarding her LG dryer.
Her complaint was that the laundry was not dry at the end of the cycle.
Also---the cycle run time/duration was rather short (cycle ended far earlier than initial time displayed).
In her case---she does not wash/dry large loads at all---and rarely does she even have medium sized loads to wash.
On LG dryers---the MOISTURE SENSOR ("bars") are located at the front of the dryer---on the LINT FILTER HOUSING.
If the dryer is dead-level---which hers was---a small load of laundry will tumble in the GIANT DRUM and very erratically come into contact with the MOISTURE SENSOR.
By raising the REAR LEVELING LEGS about an inch---this forced the tumbling small load of laundry to remain at the *front* of the dryer---continually falling/contacting the MOISTURE SENSOR.
On dryers (other brands) in which the sensors are positioned at the rear/back of the drum---simply raise the *front* leveling legs to get the same result.
Technicians can demonstrate to the customer by running the dryer with 2 or 3 small pieces of clothing---laundry will either tumble at the rear of the drum or near the center (in an LG dryer--for example).
Explain to the customer---the MOISTURE SENSORs function and that wet/damp laundry *must* continually come into contact with the sensor (show the customer the location of the sensor).
After adjusting the legs---the customer/owner will notice the laundry moving toward the SENSOR location within 30 seconds of starting the cycle---and remain at that location in the drum for the duration of the cycle.
Dry laundry.
Problem solved :)
Edited by john63, 10 January 2012 - 08:47 PM.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
  • 24,258 posts
Posted 10 January 2012 - 06:18 AM
Great tips, John, domo! :dude:
#3 nickfixit
nickfixit
  • 1,965 posts
Posted 10 January 2012 - 06:31 AM
I use that tactic myself, and it works well. Now if we can get people to stop running mixed loads of cottons and knits.
#4 phydeauxe64
phydeauxe64
    Yamabushi
  • 81 posts
  • Flavorite Brew:"Double D" Turbo Coffee
Posted 10 January 2012 - 04:57 PM
That is most excellent advice and very true especially in the older Kenmore and Whirlpool dryers. :rocker:
#5 john63
john63
  • 1,411 posts
Posted 11 January 2012 - 01:08 AM
Another benefit to raising the front or back of the dryer (depending upon where the MOISTURE SENSOR is located)...
Is that if a mixed load of laundry is added to the dryer (denims with t-shirts for example)---the entire load of laundry is more apt to be *dry* when the cycle ends.
In other words---if we have an LG dryer (front mounted sensor) that is DEAD-LEVEL...
Add several pairs of denims to the drum first
Then add a load of t-shirts
When the dryer is started---there's nothing to induce or force the denims (which are heavier fabrics and therefore wetter than t-shirts) to re-position within the tumbling drum from the-rear-to-the-front of the drum during the cycle.
On more than a few occassions---the customer may indicate that:
"If I add a mixed load of laundry to the dryer,the t-shirts will be dry,but the denims will be damp/wet."
With an LG dryer---raising the rear leveling legs causes the DENIMS to tumble towards the front half of the drum (contacting the MOISTURE SENSOR). The T-SHIRTS will be forced under the drum towards the rear half of the drum.
This rotating of clothing (at a slight angle) during tumble---repeats itself over and over.
The end result is that---because the heaver denims (still wet even though the t-shirts were dry) kept falling onto the MOISTURE SENSOR---the MAIN BOARD did not ***reduce*** cycle run-time earlier/sooner.
In this set up (tilting the dryer) mixed laundry loads are more consistently & evenly dried by the time the cycle ends.
Edited by john63, 11 January 2012 - 01:19 AM.
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
