Frigidaire Gallery Washer GLTF530DS0 drains but no final spin
14 replies to this topic
#1 nwilder
nwilder
  • 8 posts
Posted 10 January 2012 - 08:00 AM
Frigidaire Gallery Washer GLTF530DSO
Drains fine but no final spin, clothes are soaking wet. Not the door latch, I tried to open door when it was on spin cycle, during wash cycle and before light went out. My research on here tells me it is the speed control board. Is there a way to test this? Can this be returned if it turns out to not be the problem? Is it hard to install? Where does it go? Please help.
#2 RegUS_PatOff
  • 30,229 posts
Posted 10 January 2012 - 09:00 AM
... I tried to open door when it was on spin cycle, .
... Does it Tumble (Agitate) OK ? = Speed Control is OK
When it's in the Spin Cycle, un-plug Power Cord from Wall Outlet.
can you now open the Door right away, = bad Door Latch Assembly
OR only after a few minutes ?
http://www.repaircli...R=154&N=1531974
Door-Switch-Assembly-131763202-01235823.
  • 24,262 posts
Posted 10 January 2012 - 09:29 AM
And if the door switch checks out okay, then the problem is the motor control board ==> Motor Control Board
#4 nwilder
nwilder
  • 8 posts
Posted 10 January 2012 - 10:17 AM
Unplugged during spin cyle and door opened right up. Will be ordering part in a few days. Is this door latch hard to install? Thanks to you.
#5 nwilder
nwilder
  • 8 posts
Posted 25 January 2012 - 08:38 AM
Door latch didn't fix problem, so I ordered the other part you recommended. Is there a video to install this?
  • 24,262 posts
Posted 25 January 2012 - 09:50 AM
That other part being the motor control board? ==> http://www.repaircli...mber=GLTF530DS0
Did you disconnect/reconnect all the wiring harness connectors on the door latch, motor control board, and motor? Try dat first. If still no love, then get the board linked above.
No video for replacement but it's plug n' chug.
Although your board may look different, you can see where it's located in this pic ==> http://www.flickr.co...dman/164419360/
Mouse over the photo for the annotations.
#7 RegUS_PatOff
  • 30,229 posts
Posted 25 January 2012 - 10:31 AM
did the new Door Latch Assembly fix this problem ?
#8 jumptrout
jumptrout
  • 1,134 posts
  • Flavorite Brew:Coors Light
Posted 25 January 2012 - 02:33 PM
#9 nwilder
nwilder
  • 8 posts
Posted 25 January 2012 - 02:59 PM
I did the first recommendation of putting in spin cycle, unplugging and trying to open door. Door opened right up. So I ordered the door latch, put it on, and it still won't spin. I ordered the motor control board. Waiting on FedEx to get here today. I am into this now for $230 dollars, not sure if I made the right decision to fix or if I should have bought a new washer. Whats the lifetime on this product, anyone know?
#10 RegUS_PatOff
  • 30,229 posts
Posted 25 January 2012 - 03:04 PM
during Spin, is the Door Lock Ligt ON ?
#11 nwilder
nwilder
  • 8 posts
Posted 25 January 2012 - 03:20 PM
Yes, light on.
I think it is on, does it make a difference?
#12 RegUS_PatOff
  • 30,229 posts
Posted 25 January 2012 - 03:30 PM
... does it make a difference?
I wouldn't have asked ...
If it's not ON, the Dispenser Drawer Magnet / Switch may not be working
#13 nwilder
nwilder
  • 8 posts
Posted 25 January 2012 - 03:39 PM
Sorry, I am a little slow today. I will go check. I do know that after I changed door latch, I put it in spin, unplugged and door would not open.
#14 RegUS_PatOff
  • 30,229 posts
Posted 25 January 2012 - 03:45 PM
... t after I changed door latch, I put it in spin, unplugged and door would not open.
that's what I asked you a few messages ago...
then that means the old Door Latch Assembly was bad..
(your Washer may also have another problem)
#15 nwilder
nwilder
  • 8 posts
Posted 25 January 2012 - 03:52 PM
It still won't spin. Gonna put new piece on and see if that works.
