kenmore washer 417.41042000 not performing final spin
6 replies to this topic
#1 boombastic
boombastic
  • 2 posts
  • Flavorite Brew:red hook
Posted 11 January 2012 - 12:48 AM
My Kenmore front load washer does all other cycles but has a problem going into final spin. This happened after I replace the shocker arms after one broke.Now it won't perform final spin unless the load is lessened. It only agitates when the load is regular and when it does go into final spin it makes very load banging sounds.Please help.
    Shōgun
  • Master Samurai Tech
  • 30,931 posts
Posted 11 January 2012 - 12:14 PM
Ruh row-- I think we might be dealing with a broken drum support spider here, which would also explain why the shocks broke in the first place. Open the door, reach in and grab the lip of the inner basket. If you can move it all independently from the outer drum, then that's a hit on the broken drum spider.
#3 boombastic
boombastic
  • 2 posts
Posted 12 January 2012 - 12:13 AM
WOW Yes it feels like the inner drum is not connected to the outer drum.Samurai Repairman, what are alternate names for "drum support spider " I cannot seem to find a part with this name on the tech diagrams for this washer.
#4 john63
john63
    Dean of LG Appliantology
  • 2,218 posts
Posted 12 January 2012 - 12:46 AM
Part number: AP2107258
Edited by Samurai Appliance Repair Man, 12 January 2012 - 07:17 AM.
Modified part link using the yellow APP button in the editor tool bar to make it affiliate-able.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#5 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 12 January 2012 - 02:59 AM
Basket # 16
#6 phydeauxe64
phydeauxe64
    Sōhei
  • Chief Appliantologist
  • 104 posts
  • Flavorite Brew:"Double D" Turbo Coffee
Posted 14 January 2012 - 05:12 PM
That my friend is a MAJOR repair. I'm here to tell ya, better call in some back up on this one buddy yer gonna need it. it's alot easier to do with 2 people. :answer:
#7 RegUS_PatOff
  • 33,588 posts
Posted 14 January 2012 - 05:24 PM
casued by a broken Spider (of Basket) (inner circle on diagram)
common problem on FrigidIaire front load Washers,
especially if non-HD Detergent is used
http://fixitnow.com/...etallic-misery/
