LG Condenser Dryer not drying as well as it used to
LG Condenser Not drying
7 replies to this topic
#1 Ultrablast
Ultrablast
  • 4 posts
Posted 11 January 2012 - 06:06 AM
Our LG condenser dryer used to dry a full load on the high temp setting but now takes twice as long. I have checked the following:
Condenser is clean
All air ducts and filters are clean
Water lift pump works
Water piping is clear
Water tank is filling up
Heater is getting hot
Any ideas? Is it possible that the heater is partially faulty?
#2 john63
john63
  • 1,411 posts
Posted 11 January 2012 - 01:39 PM
Post the MODEL and SERIAL numbers.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#3 Ultrablast
Ultrablast
  • 4 posts
Posted 12 January 2012 - 04:02 AM
Model TD-C70045E. Don't know the serial number - haven't found the plate yet.
  • 24,698 posts
Posted 12 January 2012 - 07:36 AM
Help locating the model/serial number tag here ==> http://www.repaircli...My-Model-Number
#5 RegUS_PatOff
  • 30,689 posts
Posted 12 January 2012 - 09:52 AM
LG TD-C70045E
7 kg Condensor dryer
.uk / .za / ect.
#6 Ultrablast
Ultrablast
  • 4 posts
Posted 12 January 2012 - 11:33 AM
LG TD-C70045E 7 kg Condensor dryer .uk / .za / ect. Posted Image
Oss Sensei! Dat's da one!
#7 john63
john63
  • 1,411 posts
Posted 12 January 2012 - 08:37 PM
I've only seen/serviced two of these (model number is different though).
One training seminar *did* have this condensation-type dryer for review/tear-down.
This dryer is one of the very few that LG does *not* manufacture---it's an Italian design. I cannot recall the name of the manufacturer (possibly Merloni).
It is also a very "unfriendly" design to service.
Having inspected the heating element/condenser tray---you'll likely need to begin dis-assembling the dryer to effectively/properly remove lint accumulation.
Not that I regret it---this is one of the few LG branded appliances that I *don't* have much experience with :)
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#8 Ultrablast
Ultrablast
  • 4 posts
Posted 13 January 2012 - 07:53 AM
Thanks for the input. I'll see if I can figure out how to get the top and sides off this weekend and check for lint accumulation as you suggest. I've bought a new thermostat and I'll fit that as the next step.
It has 2 temp settings (high and low) and although we've pushed the high temp button, its behaving as if we'd selected low - i.e. there is definately hot air. Do these things have a 2-stage heater? In other words is there a seperate part of the element that comes on when high temp is selected or does high temp just send more current to the element?
Also tagged with one or more of these keywords: LG, Condenser, Not drying
